A question
This scheme has no input and output buffers, which are desirable for preserving the tone.
Tell me, how are things at this pedal with input and output impedances?
What are their sizes
Does it make sense to add buffers or input impedance is 1 megohm and the output does not exceed 50 kilo ohms Just as interesting about these schemes
In the effect pedals it is recommended to create circuits with a high input resistance around megohms
And a low output resistance of not more than 10 kilo ohm
Usually buffers are used for these purposes, in the buffers the signal leaves the emitter or source
Here, on the input and output cascades, the sound goes through the drain
How does this affect resistance?
The filter at the end of Marvel Drive has 2 resistors with a nominal value of 50 kilo ohms, will the output resistance be 50 kilo ohms
