In the world of stompboxes, there are many ways to protect the circuit from the wrong polarity
But the most common are circuits using diodes 1N4001-1N4007 or Schottky diodes (usually 1N5817).
I attach the schematics below
Advantages of the scheme with 4001 - no loss of voltage
Lack of 4001 - the circuit does not always save, the diode can fail and the circuit will burn, it can also burn the power source
The drawback of the circuit is from 5817 - it gives a voltage drop of 0.45 volts.
Are there any more disadvantages?
What are the advantages?
I noticed that both schemes are often found in stoppboxes, but the scheme with 4001 is considered unreliable.
Tell us what schemes you use and what their pros and cons are.
