I got asked to check that old smelly mxr m117. Apparently it's regen (feedback/resonance) knob is not working properly and does not provide as much change as you can see on this video:
1st I've wiped all rosin with a solvent
then, I've checked the pcb for any cold solder joints with my dmm
checked all resistors and pots (all intact)
still not sure about caps, at least no shorts
BBD clock is okay (I've checked it with my scope, just in case)
I've drawn all my voltages on the schematic below, they seem ok for me
Unfortunately, all trimmers are jammed with a healthy portion of solder (thanks, MXR!) - maybe 20k feedback trimpot is the reason?
I feel mentally exhausted, since i can't come with any idea or use my soldering iron to unjam the trimpot (i got asked not to do it by the guy who brought me this pedal)...
