Did some work on wahs inspired by Bajaman inital comments and after some time I realised that it was a real improvement putting in some of the original Vox V847 values, I built another wah using the
original 1967 Vox V847 schematic.
I used
Michael Manny's pcb reproduction files but used the correct values. Be aware that Hanney's component layout has a typo: the first 470k resistor should be 470R. I had a lot carbon comp resistors and a bag of tropical fishes, but not the correct values, so I went the "no mojo way" and opted for metal film resistors and WIMA 5% caps. As noted earlier, I am using two Jameco 2.2uF electrolytes in parallel - they measured 2.0x uF a piece.
The
Whippple Inductor is an immediate audible improvement -- it just sounds absolutely WAHWAH. If anybody has a red or yellow fasel lying around it would be interesting to measure its resistance, but the Whipple has 29-30 ohms, and if we suppose that the inductance is a little over 500mH, it is supposed to be a replacement for the
1967 Vox halo - large centre hole inductor
Castledine says that "some Clyde McCoys used 100k," but that's the value in the factory schematic above. Anyway, the resistance of the inductor coil will always have more influence on the total resitance across the the coil (including the parallel resistor). Total resistance will be 29.97-29.99 R. My question is: does the parallel resistor influence the inductance of the coil?
What would happen if I would put a 47R resistor in there to bring down the resistance of a bad sounding cheaper coil like the 99 Cry Baby (58R).
I also bought an ICAR pot from MIke who sells the Whipple inductor, but at this moment his store doesn't list any separately (only in kits- but talk to the guy). They are also available from
Small Bear I regret not having tried a Whipple in an stock Cry Baby yet, but I can say the Whipple in combination with the ICAR pot is wah heaven. It does gives you a steeper sweep - I believe it's reverse tapered. But as important as the taper is the dead zone at the tip - you reach 0k (maximum treble) before the end of the pot taper, so you still have space to push down the switch. I tested some Dunlop pots and none of them had a dead zone - which implies that you'll always have some resistance on the pot before you reach the switch. Even the Tawainese blue pots (cf Banzai etc) are better in this respect.
The transistor type is not important, in my opinion, as long as they are medium gain (around 250Hfe). High gain is not what the vintage wah likes, remember that since the original, the 470R resistor kept on decreasing over the years, Cry Babies now having 390R (?) - which increases gain. The known mod pages also list this as the way to get more bass - but it natural and logical for gain and bass to go hand in hand. Bajaman suggested 510R here, which got me thinking..
I do not know what the buffer is doing when it's doing nothing, so I always remove it and make them true bypass.
Anyways: here's my
SWELL MOD to end my long story: replace the C5 in a Crybaby (10n) by 68n and you'll have a pedal that swells as nice as it wahwahed. Or use a switch.
Furthermore, I don't think I'll be able to try out the
SmallBear Wah Inductor Kit next time...
