Fuzzer wrote:Thanks for the tip, but also, according to fuzzcentral, some old Clyde McCoys used a non-polar 4 [uF], Ducati brand. I'll have to wait to try the change, because I have the 3.3 NP but ran out of .68 [uF]. If you try it fist let me know, please, I'd appreciate it greatly.
You can make a 4uF non polarized by putting two 2.2uF caps in parallel too. If you connect each + to the - in the other cap, you have a non polarized. If you have some cheap electrolytics in stock, you will see you will get 4.05uF or so. I'm really stupid except that I bought a DMM with capacitance meter and I know now the below is bullshit.
[quote="from
diystompbox wiki]From Jack Orman:You can simulate a non-polarized by using 2 electrolytic caps. Connect them together negative to negative and use the positive leads as the component leads; which is probably why someone notated it as +-||--||-+
From R.G.
"You can make a quick and dirty NP cap by tying together the negatives of two equal-sized polar caps.
In the series-NP connection, the capacitance value is funny. Normally caps in series are a smaller capacitance than either cap by itself. If you had two 3.3uF polyester caps, then the expected value for two of them in series is 1.65uF. However, electrolytic caps actually conduct in the reverse direction, so two 3.3uF polarized aluminum electrolytic caps act like they each have a diode in parallel with them that conducts when the voltage is backwards for that one cap. S
o two 3.3uF caps hooked up as series non polar (i.e. negative to negative) look like a single 3.3uF NP cap.
... except for tiny region near zero volts where they withstand a tiny reverse voltage, so they look like 1.65uF there..." [/code]
I even had to read this 3 times, but: I know capacitance in parallel adds up
when I connect the +'s together and measure two 1uF electrolytics in parallel = 2uF
when I connect the + to the - and measure two 1uF electrolytics in parallel = 2uF
when I connect the +'s together and measure two 1uF electrolytics in series = 550nF
when I connect the -'s together and measure two 1uF electrolytics in parallel = 550nF
when I connect the + and the - together and measure two 1uF electrolytics in parallel = 550nF
There are a lot of problems regarding the Technology of the Wah article as the definite words about wahs.
Cout -- still working this one --
Cef-- still working this one --
Also, these 10nF capacitors were not tropical fish Mullards, but polystyrene as we know from Fuzzcentral documentation. The Mullards are 20% tolerance, so falling for these vintage suckers may degrade your sound to below Behringer wah level... As Bajaman noted earlier, these are the caps that have to make your pedal wah through an entire octave, and as the rule of thumb that is more to go by than the entire Technology article
"Let me know how that change sounds..."
The big unknown in the equation is the impedance of the wah coil. I agree as stated above, that a 100k pot in parallel with the coil (instead of the 33k or 100k) does not affect a stock Crybaby circuit. I always kick out the buffer (first thing) of Crybabies, makes them sound hard and boosted, while a real nice wah should be sweet and I'd almost say 'thin'.
m
