Nocentelli's JFET boost with Baxandall [documentation]
- Nocentelli
- Has thanked: 1115 times
- Been thanked: 939 times
A simple boost/preamp circuit I put together recently. The JFET starts to clip in a pleasingly smooth manner if you really dig in so the gain control allows you to set how hard you need to play to make this happen. The simple active two band EQ gives a nice range of tones for not many parts.
- Nocentelli
I think the JFET gives a certain je ne sais quoi that an op amp booster doesn't, i.e. mainly a little bit of distortion/compression on the edge of the notes when you hit the guitar hard. Apart from that, I had one single decent spec J201 left in my stash of through-holes that I wanted to make into something useful
Since posting the schematic, I have attempted to design a small and efficient veroboard layout and have (re)discovered that single op amps are terrible for efficient use of space. I've done another schematic for a transistor-based baxandall stage, which should be much easier to lay out nice and small. I'll post the new schem when I'm happy it works properly and sounds as good as the one above.
- Nocentelli
- Nocentelli
Verified, and I'm quite pleased with the result: A 1kC gain pot is highly recommended for smooth transition from totally clean to pleasantly gritty throughout the whole rotation. If i played a strat/tele all the time I might be tempted to omit the gain pot (jumpered flat-out) and just use the volume pot to adjust the grit. I'm going to try it out again in the near future with some other FETs as I still have some decent spec'd thru-hole 2N5457s left.
Building this from the second schematic. Just a heads up, the 100nF cap is missing from the layout, and the 47uF electrolytic off of the BC109 is labeled as 22uF on the layout. Cheers!
~bb
~bb
I'm reading that Baxandall = active = log pots, where James = passive = lin pots, but I don't know enough to know if the BC109C at the end makes this active or just buffered output or not. And, I'm seeing more schematics with lin (or no taper defined) than log. Can anyone add any clarity?
-bb
-bb
- bajaman
- Has thanked: 566 times
- Been thanked: 2014 times
should be linear pots
Thanks! These 9mm pots are a pain to wire and I didn't want to breadboard it again. Any idea where the idea of logs in a Baxandall might've come from? The active vs passive story sounded like a plausible narrative to me.
-bb
-bb
