Relay Bypass With Microcontroller
POTL
Has thanked: 58 times
Been thanked: 67 times
Post by POTL »
Hello
I again asked the bypass question on the relay, using a microcontroller.
I see several circuits that are similar, but the microcontrollers are different
Basically it's Attiny13 / Attiny85 / Pic12F675
I'm still far from digital technologies and I want to start studying these technologies, tell me about the difference between these microcontrollers in the operation of the bypass switch.
Will there be any difference in the work or for these purposes the microcontroller model does not play a significant role?
kingmafw
my favorite amplifier: Yerasov Gavrosh 10
Completed builds: Dr. Boogie - Asphyx - Holland
Sharkfin - Papaformigas - Holland
Dr. Boogie - Soulskinner - Greece
Tim Screamer - Chaedrist - Germany
Tubescreamer - Detlef Hoeller - Germany
Tubescreamer - Richard Güth - Germany
Stereo merger - the Bruceband - the Netherlands
Passive Y-box - the Bruceband - the Netherlands
Tremolo
Has thanked: 15 times
Been thanked: 15 times
Post by kingmafw »
In my opinion the microcontroller is only the tool to get it done. Food for thought can be found here:
Microchip PIC:
http://www.coda-effects.com/2017/02/rel ... -code.html
ATtiny:
viewtopic.php?f=13&t=24589&hilit=pruttelherrie
it is mei sizzen net to dwaen
Johannes Harald Kingma - FWS Pedals - Germany
POTL
Post by POTL »
Thanks, I read, I'm wondering if there is a difference in the performance of these microcontrollers, I'm interested in making 2 modes of operation:
1) Turning on and off
2) Switching on by holding the button and turning off by releasing the button
Can both of these types of microcontrollers work equally well?
Is there a difference?
marshmellow
Has thanked: 19 times
Been thanked: 126 times
Post by marshmellow »
Any controller can do that. It's just a matter of preference for the designer.
J0K3RX
Has thanked: 315 times
Been thanked: 555 times
Post by J0K3RX »
POTL
Post by POTL »
marshmellow wrote:Any controller can do that. It's just a matter of preference for the designer.
thanks
POTL
Post by POTL »
J0K3RX wrote:or, you can try these..
https://guyatoneus.com/shop/3pdt-smooth ... ro-series/
thanks, but I do not see the point of paying $ 15 per switch, it's 10 times more expensive than the usual 3pdt in china
POTL
Post by POTL »
for this bypass, an anti-click resistor of 1 mega-ohm between the ground and the input is not needed
plush
Has thanked: 35 times
Been thanked: 160 times
Post by plush »
POTL wrote:for this bypass, an anti-click resistor of 1 mega-ohm between the ground and the input is not needed
1-10Mohm pull down resistor is used to drain signal caps and mitigate the potential differences once the pedal is turned on.
It has nothing to do with the relay/3pdt click noise which both do have.
I guess you should leave your pull down resistor in it's place.
To mitigate relay click noise (debouncing), 5-10ms of soft or hard muting (via optofet) is normally applied. Muting means that you cut your signal to ground for a period of time untill your relay contacts stop bouncing. Contact bouncing could be very noticeable in high gain circuits or delay/reverb lines. ...small signal relays are more prone to bouncing, since their contacts groups are thinner and more springy than your typical 3pdt's.
black03
Post by black03 »
Even with an optofet, pop or click noise is still heard in a speaker, if you are at a high volume. After a lot of research I think there is no solution to completely eliminate the noise.
plush
Post by plush »
If so, there is an issue with your optofet or your code.
I have no click noise in mine. I've measured it with my scope, there is a slight bump (due to fet's resistance turning on/off very fast), but it's not audible at all.
black03
Post by black03 »
There is no code problem, I have consulted a lot and everyone determines that it is almost impossible to eliminate the noise completely. When there is loud volume, the noise will appear, I do not know how to show you an audio so you can check
Optical
Has thanked: 16 times
Post by Optical »
You can control ramping of the optofet to some extent using variable current control from the processor
How is the overall impression of the optofet causing a momentary muting?
black03
Post by black03 »
Optical wrote:You can control ramping of the optofet to some extent using variable current control from the processor
I understand that and it is ok, the problem is to energize the circuit the pop is still, of course much more light than a 3pdt, but all the brands of pedals have the noise, there is none that has managed to eliminate it completely. In fact, suhr uses a slightly louder switch and I understand that it makes pop lessen.
but wampler, strymon, bogner, lovepedal, catalinbread, digitech, etc etc all have noise unfortunately.
If you have the solution, please help me! I am using the coda circuit
Optical
Post by Optical »
Are you using an optofet?
It seems to me that the pop could be reduced or eliminated by ramping the fet conductance rather than switching it from high to low a fast as it can
black03
Post by black03 »
Optical wrote:Are you using an optofet?
Yes, I use the p222A
black03
Post by black03 »
Can you explain how that would be?
