MXR - Super Badass Variac Fuzz [schematic]
Hello,
As I am an avid cloner myself, I thought that it's my time to give something to the DIY community. I got ahold of the effect mentioned in the title and I am providing some gut shots, also a list with components. Capacitor values on the list have "?" due to my lack of experience with SMD components. Where there is no indication on the list will be completed tomorrow then I'll get a magnifying glass. All other info from the list are markings on the components (mostly SMD).
Here are some links to the pictures. The final picture is the components list.
https://ibb.co/k3Rwuw
https://ibb.co/ctMMuw
https://ibb.co/i931uw
https://ibb.co/hWUruw
https://ibb.co/cMgh1b
https://ibb.co/g8bRSG
https://ibb.co/imkLnG
https://ibb.co/cDMt7G
https://ibb.co/irOHZw
https://ibb.co/eyf9gb
https://ibb.co/e34D7G
https://ibb.co/jKjVnG
https://ibb.co/fywMuw
https://ibb.co/jRmnZw
https://ibb.co/k7VQMb
https://ibb.co/gjOO7G
https://ibb.co/jF7uEw
- modman
- a d m i n
- Has thanked: 4287 times
- Been thanked: 2008 times
- MXR Variac Fuzz05.jpg (31.62 KiB) Viewed 4542 times
- MXR Variac Fuzz06.jpg (24.03 KiB) Viewed 4542 times
- my favorite amplifier: Marshall
- Completed builds: Many, many...many. Fuzz man....
Hello... I think I saw a YouTube video, where the guy explains how the "super badass" came about... It's a "Band of Gypsy" fuzz with a tone added....and then the "variac" circut added on...
You could start your search there...
Good luck
Good luck
Hello All
I'm hoping that there's still some interest in decoding this pedal as I bought one that needed help off of Reverb last week and it doesn't pass audio at all when the effect is on/LED lit up.
I bought this as I like to buy broken pedals and fix them which I'm usually successful at except for a few new(er) Dunlop/MXR/WayHuge pedals that I/we cannot get schematics for.
I therefore earlier this week started a schematic "decode" of this pedal using EasyEDA and have the core effect-function of the pedal schematicized. I ran into a brick wall with regard to what I believe to be the "variac" portion of the pedal at U3 which is marked "|G114" - I did a five minute search on google and I found nothing like it which halts me in my tracks. I was earlier able to identify U1 marked K6NCD which is actually an MMDT3904, a dual 2n3904 package. I'm still trying to ID Q1 marked 9EB which measures as a PNP transistor albeit who knows which one. Some one before me also replaced Q8 and this replacement is marked 1AM - I don't know if this is actually the correct transistor or not as the pictures on this post aren't clear enough to read with regard to Q8.
I'm willing to schematicize the whole pedal if anyone can help figure out what all of the semiconductors are on the board.
In the photo with the pencil-written parts list, U4's part number is incorrect and should be TC7660SC which is the voltage-converter IC that I believe operates the 5-15VDC "variac".
I have an 94kB png image of the partial work-in-progress schematic but I don't know how to insert it here (why is it always so damned hard on a forum to just insert an image?!? -rantoff).
Dan Gibbs
Dan Gibbs
- george giblet
U3 is some sort of regulator.I believe to be the "variac" portion of the pedal at U3 which is marked "|G114" - I did a five minute search on google and I found nothing like it which halts me in my tracks.
Go to the page 5 or 6 of this thread,
viewtopic.php?f=1&t=13121
So for the Variac, U3 pin 5 goes to R30 (41.2k), then R30 to U3 pin 4,
U3 pin 4 goes to R34 (34.0k), then R34 to ground.
From that I can see, the output voltage would be,
Vo = Vref * (R30 + R34) / R34
Where Vref is the reference voltage of the regulator referred to ground. I would expect Vref to be around 1.23 to 1.25V. However, it could be 1.14 following the number printed on the chip (as some regulators are marked like that). Suppose we go with 1.25V
Vo = 1.25 * (41.2 + 34.0) / 34.0 = 2.76V
That seems low but maybe the pedal is called "variac" because the voltage is reduced; as variac would do on an amp.
So keep going! It's only power rail. You will see the rest of the circuit make more sense once you know that.
Notice the output of U3 goes to a resistor R1 (10 ohm) then to maybe looks like big cap.
- george giblet
Maybe even 11.4V. Don't worry about the details for now it might become clearer.However, it could be 1.14
FWIW, in the other link I posted I've identified a lot of parts on that unit. You might be able to copy some of that info (the text in the thread had quite a few misidentified parts so watch out).
Hello George Giblet and thanks for the info!
I've been working diligently in most of my spare time on the schematic and I think I have it all diagrammed. A crap-ton of stuff to figure out and trace for sure. I'm in the process currently of verifying traces between the actual PCB and my schematic after removing most of the through-hole components to make sure I haven't missed anything (I'm sure I have). I called and got the actual part numbers for all of the transistors and ICs last week but I shied away at that moment of asking for the diodes and SMT capacitors as I don't want to seem too greedy and burn that new bridge.
I'll definitely get back when I'm satisfied that the circuit is as correct as I can see it. The next debacle would be trying to re-arrange the schematic to where it's better than a ball of rewound yarn to where I can make sense out of the circuit sections (phwew whadda mess). I'll prolly upload it anyway once I verify the traces before I try to re-arrange.
Again, my goal here is to make a schematic to repair my non-op unit that I bought a few weeks ago. I'm not looking to clone it and I doubt it would really be worth the effort to most folks to clone it - just my opinion.
Dan
Dan
- george giblet
Same here.I'm not looking to clone it and I doubt it would really be worth the effort to most folks to clone it - just my opinion.
Ok, John Frusciante brought me here. What is the project status? How can I help? Thanks
I made an attempt at tracing this pedal.
Component side of pcb
Bottom side of pcb
Incomplete photoshop tracing. Additional connections were confirmed later on by probing for continuity with a multimeter. Magenta lines are traces on the component side of pcb. Green dots are terminations to ground plane on component side. Blue lines are traces on bottom of pcb.
Materials list. Active components were looked up by their markings. I'm not 100% confident in U3. Haven't looked up any of the diodes markings. SMD capacitors were measured with a multimeter while in circuit.
Schematic, may contain errors
Bottom side of pcb
