Page 2 of 2
Re: BAJA SLO MkII overdive pedal project 040218
Posted: 10 Jan 2020, 14:14
by 287m
Wowsshhh. Finally, my favorite circuit.
Shit, out of njfet. Why this come after place order
didnt think fit in 1590B
unless 9mm pots came.
Thanks Baja!
plush wrote:287m wrote:
or where the best position to experiment?
Between clipping diodes and output buffer. Don't forget to decouple.
If any volume drop occurs, you can replace output buffer with a power booster.
Or add another gain stage to look like this: ->[clipping diodes]->[buffer/amplifier]->[tonestack]->[output buffer/amplifier]->[volume knob]
You can find classic soldano tonestack in gewgl.
latest build, stacked with baxandall tmb style. Im not satisfied, but he said good enough.
Posted: 17 May 2020, 11:22
by mkenny17
bump. still waiting for PCB Layout or Vero Layout for the MkIII SLO Overdrive
Posted: 17 May 2020, 13:46
by FiveseveN
mkenny17 wrote: ↑17 May 2020, 11:22
still waiting
WTF is keeping you from making one? If you don't know how, take it as an opportunity to learn.
Posted: 17 May 2020, 15:49
by mkenny17
FiveseveN wrote: ↑17 May 2020, 13:46
still waiting
well yeah, thanks for the advice. but currently as i type this i'm also learning how to make it happen.
Posted: 17 May 2020, 19:25
by FiveseveN
Alright, now we're talking. What software are you working with? I've been meaning to switch to KiCad myself and it looks like there are plenty of learning resources.
Posted: 18 May 2020, 06:45
by rockola
FiveseveN wrote: ↑17 May 2020, 19:25
Here's a KiCAD learning resource for you: I redrew the schematic in KiCAD, you can download it from
https://github.com/rockola/slo-overdrive
Just import the schematic to pcbnew (literally one mouse click) and lay out the PCB.
PS: there are some small cosmetic differences, notably I drew Vbias pointing up where possible, however the schematic should be 100% equivalent to bajaman's MkIII, let me know if there are errors. I also didn't include the bypass switch nor the LED.
KiCad 5 is required. Latest (and recommended) version is 5.1.6, however I'm using the development version, let me know if it doesn't open for you.
PPS: Footprints have not been assigned so there's a bit more work to get to that one mouse click.
Posted: 18 May 2020, 08:16
by FiveseveN
Way to leave a guy without excuses to procrastinate!
I'm actually working on a hybrid (Blackstar HT style) SLO preamp so I'll probably do that one instead. There's some info about its current state in
this log, under "Tube Boomer".
Maybe mkenny17 will tackle it if going for KiCad as well.
Posted: 27 Jun 2020, 00:11
by SYK0T3K
Guys, can someone explain to me what is the need for multiple gain stages?
Posted: 27 Jun 2020, 12:17
by bajaman
"Guys, can someone explain to me what is the need for multiple gain stages?"
answer: read the first post in this thread
Posted: 10 Jan 2021, 19:03
by Repo
Is there a demo of this pedal somewhere?
Posted: 08 Jun 2021, 12:50
by PCBGuitarMan
For the ones asking for demos check the link below:
This Circuit is Amazing!
Posted: 12 Feb 2023, 03:31
by Musikermomo
Made a layout for MKIII. Probably many mistakes, but its a start.
Posted: 12 Feb 2023, 03:34
by Musikermomo
Made a layout for MKIII (MKII + tonestack) [untested]. Should fit in a 1590BB Enclosure. Probably some mistakes in it, but its a start.
Schematic is from this post:
Posted: 12 Feb 2023, 11:56
by Axldeziak
Musikermomo wrote: ↑12 Feb 2023, 03:34
can send kicad files if someone is interested.
why not just zip the files and post it here for everyone?
Posted: 13 Feb 2023, 17:10
by Musikermomo
Axldeziak wrote: ↑12 Feb 2023, 11:56
OK done, didn't know you could upload zips
![a_doh [smilie=a_doh.gif]](./images/smilies/a_doh.gif)
