Hey all,
I finished my Normal Channel vero build (the layout is attached below). Fired up first thing and didn't need any debugging.
I did make one modification, changing the 470n cap to 47n (which is the coupling cap most AC-30 schematics show before the normal channel volume pot). It reduces the gain on the bass somewhat, which is a good thing (see below). Also added a reverse polarity diode, FWIW.
The sound is pretty gainy and exactly what you would expect from the AC-30 Normal channel - which is to say "wooly". That is, it allows a lot of bass frequencies through, just like the old AC-30s. It's not a great tone when overdriven (at least for for me) -
until you add a treble booster in front. It then sounds GREAT! I am using a ROG Omega Booster pedal I built a while back and it's a good match for the amp sim as it can greatly reduce the bass frequencies going into the pedal. You could also try a Greg Fryer treble booster or a Rangemaster, but make sure you can control the level as you don't want to slam the JFET and first op amp with a huge signal.
With a treble booster in front, the treble cut control becomes useful for taming any shrillness. Works pretty well for that. I didn't try the speaker sim Bajaman introduced above, and that may provide some subtle shading of the tone. I would propose putting that circuit on a separate vero so you can experiment. Other cab sims would be interesting to try as well.
The vero is verified but let me know if any problems are found. Cheers!
