Hi, thanks for responding, so you say I should keep filtering on each one? and only with a resistance one the power sections? I hope to understand wellPOTL wrote:Hi
Do you want to build 2 pedals in 1 enclosure?
You need to create a separate power filter for each circuit.
In fact, the simplest option would be to connect 2 resistors of 100 ohms
From each resistor, the power will flow into its circuit.
What's the point of mentioning dc resistance at the input of the power section? They are present here simply for reverse polarity protection (they burn of overcurrent instead of parallel connected diode).POTL wrote:resistor
