I am willing to build a modded Valvecaster, and i would need some advices from the community.
I picked some hints from the nice document found here : https://cdn.instructables.com/ORIG/FXM/ ... 1FLK5B.pdf
The mods are :
1- feeding it 12V (instead of 9V) to get more headroom and have the tube work at the texpected specs.
2- adding a regulator to get rid of hum and buzz.
3- being able to have more gain if desired, by adding a switch.
4- bass boost mod.
My questions are the following :
1- Is the overall wiring correct (For the 3PDT, i followed the general MadBean/TagboardFX wiring) ?
2- I am not a total newbie, but still a beginner. So, i don't know at all if the "gain mod" would work (original circuit use a 50K pot, and some users complain there is not enough gain. One user said that with a 1M pot, the gain allowed for "massive saturation", so i thought that adding a 470K resistor in serie would give a 530K value, and thus giving more gain : am i correct
3- is the wiring for the bass boost mod ok ?
4- I have read that the overall tone is dark, and that even when fully clockwise, the tone pot sucks high frequency : is there any way to know it from the component values ? And, can i change some component to have the pedal sound brighter (full spectrum) when the tone pot is full clockwise ?
5- I am planning to use the pedal with synths (not guitars) : i would like to know if some capacitors in the early signal path are cutting low frequencies or high frequencies ( = is the pedal tuned for guitar, or "general purpose") ? Getting rid of the some bass mud before hitting the tube is fine, but i would like to know, to learn about it
Thank you in advance !
https://app.box.com/s/8ruzweseil3apgaeegcavm2lgtkb5u0h
