BAJA Mars Hall 1959 plexi amp overdrive pedal 9v 090318  [documentation]
Hot off the drawing board - vero layout to follow shortly :wink:
This is the amplifier that after the VOX AC30 changed the sound of British rock for ever - based on the circuit of the 1959 Fender Tweed Bassman it used the European EL34 entode output tubes because they were a lot easier and most probably a lot cheaper for Jim Marshall to purchase in post WWII Great Britain.
enjoy and have fun :D
Frank_NH
Has thanked: 99 times
Been thanked: 144 times
Post by Frank_NH »
Whoo hoo. I'm running out of TL064s!! Thanks again.
HEAD
Has thanked: 24 times
Been thanked: 46 times
Post by HEAD »
Frank_NH wrote:Whoo hoo. I'm running out of TL064s!! Thanks again.
... still waiting for mine to arrive. Running out of 100k pots, too! :D
Baja Mars Hall 1959 vero cuts.png (7.4 KiB) Viewed 7211 times
Baja Mars Hall 1959 Plexi amplifier overdrive 9v parts not on board 090318.GIF
roseblood11
Has thanked: 359 times
Been thanked: 312 times
Post by roseblood11 »
What's the advantage of the tl062 over the 072 or other opamps here?
HEAD
Post by HEAD »
... lower slew rate -> less harsh sound.
Frank_NH
Post by Frank_NH »
Quick question. Did you intend to have 100K to ground for the JFET buffer?
Good spotting - Yes - I found it improves the signal to noise ratio as the fet is now running at a much lower current.
Frank_NH
Post by Frank_NH »
OK. Yes, 100K will lower the current flow, though wouldn't the higher resistance introduce more noise? :hmmm: Well I can simulate it in LTspice and see. Thanks!
287m
Has thanked: 472 times
Been thanked: 72 times
Post by 287m »
first try in perf :scratch:
FausterCraster
Has thanked: 17 times
Post by FausterCraster »
Baja this is the best pedal I ever played !! :applause: :applause: :applause: :applause: :applause:
Below my (verified) 24x18 hole board. Enjoy it !!
gght
Has thanked: 47 times
Post by gght »
Anyone have clip to listen to this??
A couple of small errors on the original vero - this one is verified - i built it and it works well :wink:
Baja Mars Hall 1959 vero cuts.png (7.4 KiB) Viewed 6979 times
:oops:
some pictures of my build - recycled enclosure again :lol:
gght
Post by gght »
Sweet
HEAD
Post by HEAD »
287m wrote:first try in perf :scratch:
Edit: Made a mistake and fixed it.
95H
Has thanked: 16 times
Post by 95H »
Hallo,
what type of capacitors are used away from the 1uF multilayer ceramic?
287m
Post by 287m »
95H wrote:Hallo,
MLCC, like this
95H
Post by 95H »
287m wrote:
95H wrote:Hallo,
MLCC, like this
The question was what type of caps for the other values than the 1uF. Except electrolyte .
287m
Post by 287m »
I build all with MLCC, because all i have.
But you can use poly box caps and/or ceramic for some pF value
