BAJA Orange AD200B MkII bass amplifier in a 9v pedal 270318  [documentation]
Hi folks
here is something a little different - a bass amplifier 9v effects pedal :shock:
not built yet, but will post pictures when it is :wink:
vero cuts.png (7.39 KiB) Viewed 7915 times
ok folks - I built it and it is now verified :wink:
HOWEVER - one small mistake on the vero layout (4k7 resistor connected to wrong side of driver stage clipping diodes).
I did feel that the gain was a little too low as well - i had to have all the controls on max to get any output stage clipping, so i increased the two preamp gain stages by 15dB (changed the 2k2 feedback resistors to 6k8). To maintain the same high frequency rolloff characteristic and phase shift I had to decrease the paralleled ceramic capacitors by the inverse of the gain (x .324 times).
Anyway here is the rev 1 vero layout and schematic - build pictures will follow tomorrow when it is daylight.
Happy Easter to all - try not to eat too much chocolate - lol :roll:
deltafred
Has thanked: 808 times
Been thanked: 299 times
Post by deltafred »
Mmmmm, bass amps.
Many thanks Bajaman.
here is my prototype build - I ran out of TL072 opamps so used some OPA2134 devices I had lying around - a bit of overkill but sounds really nice.
I really like the sound and feel of the Orange AD200B bass amp - has a really fat sound with a natural growl - very simple but effective sounding design in my humble opinion :D
BlueMeany
Post by BlueMeany »
Hi Baja, cool stuff! What is going on with the tl062 stage? Looks interesting.
Groovenut
Has thanked: 60 times
Been thanked: 100 times
Post by Groovenut »
BlueMeany wrote:Hi Baja, cool stuff! What is going on with the tl062 stage? Looks interesting.
I believe it is modeling the output stage behavior
BlueMeany
Post by BlueMeany »
If Bajaman would be so kind I would love to read a few details on the tricks and techniques which are being employed to create these emulations. They certainly seem a lot more involved than the usual "amp sim" with at least one or two more layers of thought applied to them.
Hello BlueMeany.
Happy to oblige :wink: All of my designs start off by analysing the actual tube amplifier schematic in a spice program to determine the transfer characteristics including it's phase responses (most important) at all stages. Vacuum tubes have a relatively high output impedance and some amplifier designs use cathode followers in an attempt to lower this so that proceeding stages do not load the gain stage too much. They also work on typically 300 volts which allows a lot of signal headroom, especially as most tube gain stages used in tube amplifiers have typically 30dB of gain. A 1 volt signal applied to the input of such a tube amplifier section would potentially (ignoring load effects) give a 40 volt signal at the output - leaving a massive 260 volts of clean headroom :wink: However, apply this 40 volt signal to the next tube stage and the tube will attempt to deliver 1600 volts - impossible from a 300 volt supply so the tube will be driven into heavy clipping. Without going into the exact nature of how the tube clips - there are plenty of articles on line that explain grid current construction, blocking distortion etc. I would recommend Merlin Blencowes excellent "Designing Tube Preamps for Guitar and Bass" for a more in depth study :thumbsup
Back to my pedal designs - 9 volts does not allow a lot of headroom and consequently gain stages have to be trimmed considerably to give the same clean signal response as the tube amplifier individual gain stages. In my attempts to mimic the response characteristics of tube amplifiers but at 9v, I have tried using jfets, small signal low noise transistors, cmos, cmos op amps and have discovered the most realistic and practical devices to be the humble Bifet input op amps such as the TL07* and the low current draw TL06* series devices - occasionally I like to use the high spec lower noise OPA213* devices as input stage devices to keep the hiss level down, but i have found that these devices do not sound as good to my ears as output stage devices. Of course these are only my views and you may hear completely differently :wink:
The Bifet op amp has a high input impedance like a tube when used as a non inverting gain stage and a low output impedance (unlike the tube) - I like to think it has it's very own cathode follower stage built in :lol: The vacuum tube has a greater input capacitance compared to the bifet op amp and some designs exploit this with a small resistor in series with the grid - this in effect acts as a low pass filter and rolls off some high frequency harmonics BEFORE they enter the tube. the bifet op amp sometimes needs an additional capacitor fitted at the non inverting input to duplicate this tube response characteristic - some times the high frequency rolloff is achieved by placing a small capacitor in parallel with the feedback resistor in the op amp equivalent - sometimes a combination is used - whatever method gives a similar frequency and phase shift characteristic to the tube design :wink:
Before any attempt is made to recreate the tube circuit with op amps, I examine which stage clips first in the tube amplifier simulation and whether it is symmetrical or not. Then i continue increasing the signal at the input until the preceding stage clips and note whether it is symmetrical or not - i make a note of the input signal levels :wink:
In the meantime - hope this helps - check out the latest design Baja Ampeg SVT bass amplifier :)
johnk
Has thanked: 36 times
Been thanked: 293 times
Post by johnk »
being a bass player, i just drew up and etched a pcb for this one. it works and sounds good clean but unfortunately, i find the distortion to be less than desirable having a funky decay.
peterc
Has thanked: 68 times
Post by peterc »
Great description Baja, thanks for that.
Peter
try this then :wink:
johnk
Post by johnk »
just tried rev2. it still has a really ugly decay on the distortion (it sputters out as it fades- unlike an actual tube amp).
johnk
Post by johnk »
i went back to Rev1 and omitted the volume control (since the actual amp doesn't have one) and it sounds A LOT better that way (it cured the funky distortion decay). i just connected treble 2 to where it used to connect to volume 3. I also changed the bass pot's taper to an audio pot for a better sweep of the control (it previously came almost fully on right off off fully counterclockwise). the pedal sounds excellent now. thanks bajaman!
johnk
Post by johnk »
BTW, this pedal sounds awesome running at 18 volts too. at 18V it has more clean headroom and a bit more output.
chili.dog
Post by chili.dog »
This may be a dumb question, but if designing the model while limited to 9V is making it difficult, why couldn't you design around 18V and use a charge pump? Would that make things better or would it just be more headaches?
johnk
Post by johnk »
that's exactly what i did on mine.
chili.dog
Post by chili.dog »
Yes, I see that. But the pedal wasn't specifically designed around 18V. I'm asking if baja would be able to get closer to the real amp if he designed it around 18V or even higher.
AAntonio
Has thanked: 19 times
Been thanked: 16 times
Post by AAntonio »
can it be connected to a cabinet?
thetragichero
Has thanked: 17 times
Post by thetragichero »
you are welcome to hook it up to a cabinet, but if you want it to produce sound I'd suggest putting some sort of power amplifier in between
AAntonio
Post by AAntonio »
thetragichero wrote:you are welcome to hook it up to a cabinet, but if you want it to produce sound I'd suggest putting some sort of power amplifier in between
Is there a complete project to connect to a cabinet?
