Symmetrical power supply
snk
Has thanked: 105 times
Been thanked: 16 times
Post by snk »
Hello
I have built a pedal expecting a +/- 12-15V symmetrical power supply.
I am torn between two solutions : either use a 15V Meanwell PD2515PSU i have on a shelf, or modify a Tube Driver daughter board to feed my stompbox symmetrical 12V from a "normal" 12V adapter.
1 - I have no experience from wiring Meanwell PSU, so could anyone help me and tell how to wire it properly to the pedal ? On the CN2, where is the +15, the -15 and the ground ?
2 - If i go the "12V daughter board" route, what should i change on the Tube Driver daughter board to make it work fine with my FX (the Tube Driver daughter board has no ground input, and one wire at the end of the circuit is supposed to go the the tube socket : should i just ignore it ?)
Thank you !
snk
Post by snk »
I have read that in such circuit (i'm referring to the 12V daughter board on vero), the ground is "shared by the input and the output" : does this mean that i should wire both the DC ground and the circuit ground to the single hole at the bottom right of the veroboard ?
mirosol
my favorite amplifier: Been on Bogner for quite some time now.
Completed builds: Over 1000 and counting.
Has thanked: 190 times
Been thanked: 446 times
Post by mirosol »
snk wrote:I have read that in such circuit (i'm referring to the 12V daughter board on vero), the ground is "shared by the input and the output" : does this mean that i should wire both the DC ground and the circuit ground to the single hole at the bottom right of the veroboard ?
Yes. All grounds are connected together.
http://tagboardeffects.blogspot.com/
http://mirosol.kapsi.fi/
"No such thing as innocence" -Iron Chic
snk
Post by snk »
Hi, Mirosol
Thank you for your answer (and thank you as well for your website http://mirosol.kapsi.fi/ and your many contributions on tagboardeffects) !
aionios
Been thanked: 369 times
Post by aionios »
Depending on the amperage you need and the sensitivity of the parts, you may also want to check out the power supply section of the L5 Preamp:
https://aionelectronics.com/project/l5-preamp/
It uses 9VAC (not DC) and converts it to +/-15VDC with a whole lot fewer parts than that Meanwell supply. Plus, it's not switch-mode, so no risk of heterodyning or anything if there are clocks in the circuit.
snk
Post by snk »
Thank you for the tip !
So far, i am using my Meanwell, as it is already available, on my desk :)
But i will take your suggestion into consideration, as i have some other projects for the Meanwell...
