Verb Deluxe from modkitsdiy.com
codom
Post by codom »
Hi, all-
I am so new at this, I am almost embarrassed to post a question.
I am trying to repair the above mentioned pedal. When I got it, it wouldnt work at all-looking inside, I could see several direct shorts, actually about 22 of them...also, several components were mis-wired, and one component was missing-jfet pf5102, no one locally had any of these in stock-I managed to find an mpf 102, and I subbed that for the 5102, and ther were several wires soldered where they didnt belong. I desoldered all of the wiring, put components in there correct places, resoldered wiring and plugged it in expecting to hear lush reverb----no effects. I have signal all the way thru, nut thats it-my mix knob has a minuscule effect, nothing dramatic, and there is no reverb whatsoever-
I rechecked for direct shorts
I have checked voltages at certain points in the layout, and they seem to be correct or within 5%.
Its inexpensive enough that it can be replaced, but I want to repair this for the experience.
Any help would be appreciated-
codom
Post by codom »
So, are you telling me its pointless to ask for help figuring something out? Believe it or not, there was a time you needed help too...Ive hit a speed bump, and I dont know enough yet to get around it-I've traced the wiring 3 times against the Final Assembly pic, and all of it matches up. I do not know what else to do, so that is the reason Im asking for help...
why don't you go through the debugging document provided by the company?
codom
Post by codom »
I think my initial post suggests that I did. You, sir, are quite rude. If you are representative of the kind of help that is available, I think I can do without any.
codom
Post by codom »
Modman-I owe you a sincere apology-I misread your initial reply, and I am sorry...I mistakenly assumed your tagline was your response to me. My bad.
