I want to build an active Baxandall eq, but im' missing the 3.9K resistors from the BoM (i have every other component).
However, I do have both 3.3K and 4.7K resistors : i am considering using 3.3K resistors instead.
My question is the following :
- I'm assuming it is safe for the circuit to put a capacitor with a "20% average tolerance" value (i mean 3.3k instead of 3.9k), so that the circuit will still work without a big change in sound and without messing the circuit or the other components : could anyone confirm ?
- I see from the layout that the 3.9k (R8 & R9) are both linked to the treble knob. Therefore, I think that changing the capcaitor values might change either the frequency where the boost/cut occurs, or the boost/cut amount : am i right ? Could anyone tell me what exactly changing these values will change in the sound, and if i should better go for a 3.3k (value below the suggested one) or a 4.7k (value above the suggested one) ?
