Power suppy question
Posted: 08 May 2018, 16:29
I have a 3 pedal board that i supply power to via a single wall art with plenty of current. I have tried several good supplies for this and all have created various noise issues. What i finally did that quieted it completely is to add filer nodes to each supply consisting of a series resistor and cap configured the same as in a tube amp. My question is about the values. I used what i had just to give it a shot but now that i know it works i will build a small box for all the filer nodes and the question is what values would you suggest? At the moment to test it i used what i had..... 100uf and 1.5k resistors. Works fine but i want to change them anyways due to the size of the caps. I know all i need is probably 16v, but what uf and R values would you suggest? Thanks.
