What are the challenges to designing a discrete LM3080N
Belanger88
my favorite amplifier: 5150lll
Has thanked: 99 times
Been thanked: 37 times
Post by Belanger88 »
I know they’re difficult for most people to source, although I have a nice collection of genuine OTA’s I’ve always been extremely curious as to why I haven’t seen this done already. I understand the LM/NJM13700 can still be had fairly easily but you’d think in countries where importing can be difficult some resourceful person must have accomplished this
Or is there complications to designing it such as tightly matched components among other things I may not have thought of? :hmmm:
I’m a huge fan of discrete design and although I understand better performance can almost always be had by IC this day in age I still find myself a fan of discrete circuits in guitar pedals or at least sections of such as the boss blues driver or the discrete diode compression opamp
Just noticed I accidentally posted this is the wrong area, sorry about that Modman
Success is no accident. It is hard work, perseverance, learning, studying, sacrifice and most of all, love of what you are doing or learning to do.
marshmellow
Has thanked: 19 times
Been thanked: 126 times
Post by marshmellow »
Should be doable, I can't see why not. But I would recommend to simulate it in Spice first before building the circuit. In integrated design, scaling of currents is done via geometrical properties of the transistors and cross-matching. Which is something that isn't visible on a schematic like this, because a transistor looks like a transistor. But when building with discrete components, the exact behaviour is controlled by the outside parts, because you can't rely on such specs and mechanics. You might have to insert resistors in several spots to get everything working properly and predictably. The design could actually be simplified a bit, so simulation would help you in that regard.
I've been building discrete opamps as you can see in the photo. All single opamps, except the last purple one which is a dual, one amp on each pcb side. The yellow one has 10 transistors and 13 passives, which is a bit higher complexity compared to the CA3080. So you should be able to fit and build a direct plugin substitute. SMD arrays are the way to go in any case, because they already come matched and the thermal tracking is much improved compared to all singles. For the diodes use transistors as well, in the same package as the corresponding transistor.
Belanger88
Do you sell those SMD discrete opamp boards? Assembled or not :D
If not then thank you any way for your reply, I think it’s my next project to start working with then as I really really love circuits with OTA’s more and more these days and I adore discrete design and the amount of thought and effort involved in doing a project. I find that sort of job very rewarding myself!
marshmellow wrote:Should be doable, I can't see why not. But I would recommend to simulate it in Spice first before building the circuit. In integrated design, scaling of currents is done via geometrical properties of the transistors and cross-matching. Which is something that isn't visible on a schematic like this, because a transistor looks like a transistor. But when building with discrete components, the exact behaviour is controlled by the outside parts, because you can't rely on such specs and mechanics. You might have to insert resistors in several spots to get everything working properly and predictably. The design could actually be simplified a bit, so simulation would help you in that regard.
[ Image ][ Image ]
marshmellow
Sure, PM me your address and I'll send you a couple, I have more pcbs than I'll ever build in a lifetime. Same goes for anyone else interested of course. Unfortunately I don't have any more of the duals at the moment. I tested the single opamps in a Rat, Hotcake and OD250, and they do offer some tonal variety compared to the stock ICs. Nuances, not night and day differences. But like you said, I also very much enjoy discrete electronics and it's fun designing and building these circuits. It's an interesting challenge to squeeze out as much performance as possible out of 1cm² of pcb real estate :wink:.
The green one uses a dual JFET for the differential input, which went obsolete between the time I designed this a couple years ago and started building a couple months ago. It's also a very basic and simplified circuit because it used SOT23 transistors, which take up too much space to allow more advanced circuit techniques. The blue one uses a lownoise dual JFET from Toshiba and the rest is these mini duals, that allow a much higher parts density. The circuit is a simple one-stage folded cascode. The yellow one uses pnp BJT inputs with a standard two-stage topology employing more advanced elements like emitter current source, active current mirror load etc. The performance is actually good enough to use it in cleaner soundpaths (HIFI, recording, ...) as well. The red one is all FETs and a major PITA to build. Took me two hours of matching transistors and it still didn't really go where I wanted it to. I only built one :roll:. The purple one as I already said is a dual opamp. The circuit is similar to the single green one, but because of the smaller packages I was able to fit one on each side of the pcb.
Passive parts for all of these are 0603, so still ok to handle. All you need is a fine solder tip, tweezers, fine solder and flux for soldering the little 6-pin packages. The difficulty in building these isn't the size of the parts, but the closeness to each other. Soldering one resistor can reflow another one because of the overall low thermal mass of the parts and the pcb. You have to start in the middle and work your way to the outside. While there are easier things to build it could be a nice project for people who don't have much experience with soldering SMD. Parts cost per opamp is around 1,50€, so not too much of an investment.
Belanger88 wrote:Just noticed I accidentally posted this is the wrong area, sorry about that Modman
Cannot find a better place to put it - what would be a complete anachronism in real science, may be a great new approach to stompboxology.
Belanger88
So I suppose I should learn some more about sinking and sourcing current mirrors to start off with, if anyone can recommend some good reading material on either discrete design, OTA’s or sinking/sourcing current mirrors I’d really appreciate it. My day will consist of lots of research and coffee so I don’t want anyone to think that I’m not doing the work on my own either.
microbailey
Has thanked: 21 times
Been thanked: 55 times
Post by microbailey »
Hi Belanger88.
To answer your question its hard to replicate the exact behaviour of an analog circuit designed for a die (the piece of silicon in side a part like an op-amp) with discrete parts for several reasons (I'm sure there's more but these are the ones that spring to mind):
1) as already said the geometry of transistors on a die can be very carefully controlled to be within tolerances. geometry is a fancy way of saying the size of the various bits of a transistor such as the gate or channel. these sizes have an effect on the amount of current the transistor can handle and the capacitance it has at its terminals (which in turn affects its bandwidth)
2) the doping of the transistors on a die can be very accurately controlled. doping is the amount of certain chemicals added (like doping in cycling :) ) which has a huge effect on the gain of the transistor and its various performance curves. Especially in op-amps the matching of gain between 2 or more transistors is important to the performance including how much distortion it creates at certain frequencies
3) on a small die (such as an op-amp) the temperature is about the same everywhere so all the transistors are at the same point on their gain and threshold curves
4) even the transistor inter-connecting wire lengths which affect resistance and capacitance, and so frequency response of the circuit, can be accurately (within tolerances) controlled
5) the package - that's the plastic lump with legs which the silicon chip is inside - also affects the audio performance since it adds some inductance on the IC's leads
Of course analog chip designers try to design out many of the variances so each chip performs the same as the next in production, but often the way to design out these effects is to use silicon manufacturing process' ability to match transistors precisely.
All of those things (except maybe #4) are almost impossible to do nearly as accurately with discrete parts.
That's not to say there's no point in trying to build an analog IC from discretes but it will not be able to have the exact same characteristics over temperature and supply voltage as an LM308 or a CA3080 or whatever. When you get to the classic synth chips (like the Curtis chips) the characteristics are even more bound up with the matching of on-die transistors and chip layout.
Let us know how you get on with this as I'm sure you'll create something really sonically interesting.
"There's something about a Gucci loafer kicking on a fuzz pedal" Alex Turner, Arctic Monkeys
koldman
Post by koldman »
Small bear sell these new, they're back in production.
Jan1966
Been thanked: 14 times
Post by Jan1966 »
koldman wrote:Small bear sell these new, they're back in production.
same in the uk 3080's can be purchased from Bitsbox. I believe a company called Harris manufactures them now.
hgamal
Been thanked: 5 times
Post by hgamal »
I think still worth to clone one using discrete parts. Maybe a exact copy of 3080 will not produced, but a very interesting OTA will.
When I was young I dreamed with custom chip companies, delivering ICs to the people. This time has not come yet! I keep my dreams.
