Dynacord - Federhall 1960  [schematic]
borislavgajic
Has thanked: 131 times
Been thanked: 277 times
Post by borislavgajic »
please does someone have schematic for this spring reverb...?
https://reverb.com/ca/item/13111710-dyn ... 960-s-rare
borislavgajic
here are guts.....it seems that it is all wet sound...?
vintagekiki
Has thanked: 27 times
Been thanked: 15 times
Post by vintagekiki »
bow_and_error
Has thanked: 92 times
Been thanked: 41 times
Post by bow_and_error »
I have a similar tank, and this is one of only 2 circuits I've seen that uses a high input/output impedance tank with grounded input & output connectors. The other is the Nonlinear Circuits Big Room Eurorack module (based on Polyfusion VC Reverb). The high impedance of these tanks requires a lot of drive current, so they usually have higher voltage PSUs than more common lower-impedance tanks. So keep that in mind if you need to find a replacement PSU.
Here is the decoded tank information:
Dynacord Spring Reverb Tank - #4FB2A1C
Digit - Specification
1st - Reverb Type - (4) - Type 4
2nd - Input Impedance/DC Resistance - (F) - 1,475/200 Ohms
3rd - Output Impedance/DC Resistance - (B) - 2,250 Ohms/200 Ohms
4th - Decay - (2) - Medium (1.75 to 3.0 s)
5th - Connectors - (A) - Input Grounded/Output Grounded
6th - Locking Devices - (1) - No Lock
7th - Mounting Plane - (C) - Vertical, Connectors Up
You can still find replacement tanks if needed.
