MOD IDEA: would this make negative feedback of boss BF-2?
scoop
Post by scoop »
this is the full schematic
I figure this is the last opamp (buffer?) before the delay line goes to the resonance knob.
If I simply find a way to swap pins 2 and 3 of IC2 would that make the signal inverse?
Thanks for any advice!
phatt
Been thanked: 338 times
Post by phatt »
Short answer,, NO.
longer answer; Quick fix mods without a deep understanding of how something works will just lead to tears.
Messing with pcbs is the fastest way to destroy a good working pedal.
If you want to fiddle with this circuit buy the parts and breadboard your dreams. :wink:
Phil.
scoop
Post by scoop »
well luckily there is a bit of room in the BF-2, I could possibly fit a daughter board in that inverts in the path of the resonance
marshmellow
Has thanked: 19 times
Been thanked: 126 times
Post by marshmellow »
In addition to what Phil said: you can't change the polarity of the signal at that point. It would upset the phase relation of the mixer in front of the BBD, as well as the mixer of clean signal and effect signal at the output.
