Schaller - Fuzz (Germanium)  [schematic]
Schoppo
my favorite amplifier: Soldano SLO
Completed builds: Many
Been thanked: 14 times
Post by Schoppo »
Hello,
at least, after Hundreds of Years of research (aprox.) I found some Picture of the Backside from the Original Schaller GE Fuzz.
made some PCB tracing with Target3001 (E-Cad like Eagle) try to get it in here.
It`s just possible to make some pdf but no jpeg or something.
Maybe someone in here will help to finish the layout (just finished the tracing right now)
Schaller_60`sGE_Fuzz_Copper.pdf
(73.53 KiB) Downloaded 861 times
Schoppo
Post by Schoppo »
Oh, and i forgot:
the space between the Copper traces is around 1mm (all Measures in mm) just cut in, maybe milled with a thin
milling cutter, i will try try it with a dremel cutting wheel.
All very straight what makes me think it was on a milling machine (not per hand)
And be aware: there are some different layouts out of this time, i saw one with all legs of transistor 1 pulled through one big hole- for example.
Schoppo
Post by Schoppo »
SchallerGE_Fuzz_Front_Layout.PDF
(9.42 KiB) Downloaded 524 times
Here is some raw front layout. Traces are now on Back (mirrored)
Schoppo
Post by Schoppo »
Ok, some explanations:
the 100K from Q2 Emitter to Q1 Base (the angular one) goes through the holes from the Transistors legs.
The 1k (yes) Collector R covers the holes from Base and Emitter of Q2 (Q1 is left Q2 is right, sorry will make a nicer one soon :oops: )
The "Intensität" Pot (love this word :D ) is one side on Ground other side is on Q2 Emitter trace, mid (wiper)lug is wired to C on the far right upper lug (this one not on ground) and builds the emitter 2 Resistor( i think its a very common 1K lin, tried it and worked and sounded right)
Input is upper left corner on the Cap.
The pots are already unknown but "Intensität" has to be 1k i think, 100K for Volume works fine, i went down to 5k worked fine to. ther is only some little differents in highs (very little) not in bass due to the big output Cap (10µF). maybe someone here can help and solve the mystic about these pots :lol:
completed and corrected the "Raw" layout (C_Out was flipped)
SchallerGE_Fuzz_Layout_PCB.PDF
(15.81 KiB) Downloaded 350 times
Schoppo
Post by Schoppo »
Here some quick schemo:
Schaller_Fuzz_GE_Schemo_SCH.PDF
(3.09 KiB) Downloaded 616 times
Schoppo
Post by Schoppo »
Some better layout:
(15.81 KiB) Downloaded 319 times
Schoppo
Post by Schoppo »
OK, now its for sure:
"Pegel" is 100K Log and
"Intensität" is 1K Lin[/color]
Manfred
Has thanked: 1597 times
Been thanked: 1300 times
Post by Manfred »
I found this schematic:
Manfred
Post by Manfred »
On the schematic of the previous post, the connections of Emitter and Collector have been interchanged.
Manfred
Post by Manfred »
The edit function did not work twice, Here's a supplement to the previous post.
the values of the potentiometer values have been interchanged too.
Manfred
Post by Manfred »
Corrected Schematic:
Schoppo
Post by Schoppo »
I´ve seen this schematic too but its completly wrong there is also just one other schemo getting around thats full of guesses.
(But you did it "Manfred" :applause: :applause: you got it right)
Schoppo
Post by Schoppo »
oh, and thanks for jpg , didn`t know how to manage this.
Schoppo
Post by Schoppo »
but it was just a short transfer time they used AC192 (between the Ge and Si ones), from beginning they used AC151r
FUZZZZzzzz
Been thanked: 21 times
Post by FUZZZZzzzz »
Hi Guys,
I actually own this pedal. It's the heavy ' metal' enclosure with the AC192. I looked at the schematic above and have looked at my pedal (which looks like its still original) for my values. These seem to vary a bit from yours. Maybe they did different versions..
FUZZZZzzzz
note: The extra 25uF was soldered in afterwards.. although it's actually the same brand and time period. It seems legit and also done by the company itself. Therefore the 'PCB' design is the same for my pedal.
Manfred
Post by Manfred »
FUZZZZzzzz
Cool! another ' mystery' solved ;)
Schoppo
Post by Schoppo »
Wow guys,
i had alook from time to time in web and wondered for years, that there`s no Schematic/Tracing from this Fuzz before.
This is really a historic Moment!!!!!!! :applause: :applause: :applause: :applause: :applause: :applause:
Thank you Guys for sharing this with me.
By the way: I found this is one of the best sounding (Vintage)Fuzzes build, love the Sound and it´s much more versatile and useful than a Fuzzface.
Thank you FUZZZzzzz for completing it and thanks Manfred for your help.
Wow
FUZZZZzzzz
I also did a little exercise. Can probably be smaller, but I like to build things easy. Yet unverified!
