Has anyone modded their MXR Distortion + ?
masthefool
Post by masthefool »
If so, was it worth modding or did it still sound thin and like a razor blade stabbing your ears ? Im thinking of modding mine and I have never tried modding a pedal so im curious if its worth doing
Intripped
Has thanked: 941 times
Been thanked: 303 times
Post by Intripped »
Here you can find a nice article from Brian Wampler (Wampler pedals, active member here also) with some interesting mods. Hopefully you can find the most useful for you.
https://www.premierguitar.com/articles/ ... lus-mods-1
Ps: welcome!
Manfred
Has thanked: 1597 times
Been thanked: 1300 times
Post by Manfred »
I started this complete mods in the spring, but I stopped the work during the summer.
When it is getting cold outside, I start working again.
I applied two Russian GAY-63 diodes connected in series, as an approximation of the forward PN-junktion curve of an AA119 diode.
masthefool
Intripped wrote:Here you can find a nice article from Brian Wampler (Wampler pedals, active member here also) with some interesting mods. Hopefully you can find the most useful for you.
Ps: welcome!
Looking at the article, I have questions since I am new to this and cant read schematics. "Change C5 to a .0022uf and wired in series with a 1m audio taper pot" How do I wire a pot with a capacitor? Also how would i wire the spst switches ( do they replace the capacitor or resistor ? I am sorry if my questions make sense
Intripped
Post by Intripped »
If you are completely new to elctronics and diy, i think that this could be the right moment to start learning something:
How to read schematics for example, it's not difficult at all, you just have to learn the few symbols used for components.
Here is a table with many symbols. You don't need to learn them all.
The most important for pedals schematics are:
resistor, potentiometer, capacitor, diode and LED, operational amplifier (also called opamp), transistor.
Then you could try and read the schematic of the distortion plus.
I think that in a short time, with some little efforts of yours and some help from the people over here, you'll be able to make your first mod to your pedal!
alexradium
Has thanked: 64 times
Been thanked: 68 times
Post by alexradium »
In my experience when you think your pedal sounds bad,its most probably because its plugged in the wrong amp at low volume,with a lousy sounding guitar.
What is your setup?
roseblood11
Has thanked: 359 times
Been thanked: 312 times
Post by roseblood11 »
This circuit is a very good startibg point to learn the basics. Interesting things to read about: opamp circuits, high- and low pass filters, diodes as clippers.
There are a lot of circuits with the same topology, but different parts values: DOD 250, Vox 1901 Distortion, Guyatone Zoom Box PS-102.
But maybe it's easier to build a pedal from scratch than to try all those modifications on the original pcb - it might get destroyed in the process...
idy
Completed builds: FFs, Octavias, TBMKIIIs, Buzzarounds/alikes, Axis Fuzz', CS Overdriver, BMPs, Black '65s, MOSFETODs, WiiO, RAH, Klons, AC30, DLS, TSs and many variants, Small Clones, UniVibes, E. Mistress, Mutron Env Filter, Ross/Dynacomps,, EA Trems, TremLunes, Katana Boosters, BYOC Tri Boosters, other boosters and buffers, PT2399 delays, SKRM based delays, Belton Brick Reverbs, 3band parametric EQ,
Has thanked: 27 times
Been thanked: 31 times
Post by idy »
DIstortion+ is a good choice for first experiments. One of my first. I doubled the diodes. Friends were impressed. I couldn't duplicate the great sound. Finally discovered I'd broken one of the (glass) diodes. So I found I like asymetric clipping...
Yes, the "best" path is to get a breadboard and a few dollars worth of parts and start experimenting.
