I'm trying to fix my phase 95 mini. smd
the 90mode is inaudible, the 45 is working fine.
I thought the switch was the problem, but seem like the mxr switch is different from the center common switch I used.
I know is PITA to work on smd , but If someone can help which component to check or replace, i can work things out.
Sorry I dont know which schematic they used for this too
here's the board
the 45/90 switch is on the right on this pic. I just desoldered it from the pic, it's well soldered now
here's a video
