Merry Christmas to all
Here is a very simple but extremely nice sounding discrete bass guitar preamp for you all to build. Current draw is around 80uA
I recently wound a Music Man style alnico bass pickup - (low inductance but series connected - 3500 turns of 41 awg polynylon per coil
The Sadowsky schematic shows two 2N5457 low noise jfets but runs at a considerable current drain. I did not want to be constantly changing battery so I set to work designing a similar preamp but running at about 10% of the battery current draw. I was successful, and installed it in the bass, but it had too much gain and i found i could only set the bass volume to about 10% rotation, so i went back to the drawing board and thought i could do better - the circuit below. is the result and i am very pleased with it, and it has a very detailed sound to it - in my opinion far nicer than all those active op amp versions. In this two stage preamp, the jfet provides the high input impedance and sonic detail and the pnp transistor supplies the current gain and low output impedance to drive the tonestack and the proceeding effects or amplifier. The gain of each stage is set by the ratio of the 100k feedback resistor and the undecoupled 18k resistor - a voltage gain of 6.55 or +8dB for each stage. Higher (or lower) gain can be achieved by lowering (or raising) the 18k resistor value, BUT the decoupled 18k resistor will need to be increased (or decreased) by the same amount to maintain the jfet bias point. For example: changing to 10k gives +10dB, but the decoupled 18k then needs to be increased to 26k to maintain the same jfet bias
Have fun, and if you build it let us know your thoughts, suggestions etc.
bajaman the following graphs show: both controls at minimum, both controls at 50% resistance, both controls at full, treble at full rotation and bass at zero, treble at zero and bass at full rotation.
