It's four boosts all together in one box with individual toggles to switch each one in and out. I was originally going to do it with a four-position rotary switch to select which is active, but I didn't have one on-hand that would fit in the box, so I went with the toggles instead; and that's a good thing, because this way the user can have several on at once for some really cool cascaded overdrives and fuzzes.
The boosts I included are a Rangemaster Germanium Treble Boost, a super-clean opamp boost of my own design, a ZVex SHO, and Jack Orman's MiniBooster. They are wired up in that order, and all I can say is that the RM->SHO->MiniBooster combo is fuzz heaven! I think I might actually throw together a fuzz design based on that because it sounds wicked.
Here's a pic of the guts:
You can see what's going on here plainly enough. One little trick is that I used a MAX1044 to make a negative supply; this gives me a true bipolar supply for the opamp boost, and it has the added bonus of making it easy to wire the Rangemaster up with the negative supply referencing to ground, so I didn't have to wire it "upside-down" or resort to any other compromises. Also note the bias trimmer for the Rangemaster is a 10K pot used as its Emitter resistor - this is definitely the best way to go for biasing. I used an AC128 for the Ge transistor and it can do the Rangemaster thing pretty well when biased up correctly. The opamp boost uses an LF411 in a standard non-inverting sort of configuration. The SHO and MiniBooster are pretty much stock and nothing unusual.
Here is how I wired the toggles:
You might also notice I didn't use any input pull-down resistors (JHS would be proud). With the way I wired the bypass switch, I couldn't hear any noticeable popping when engaging the effect, so I decided not to compromise the "raw" input impedance of the circuits with pull-downs. The SHO sometimes makes a very faint "thunk" when switched, but it's nothing I'm worried about, and the others are very quiet with absolutely no noticeable artifacts when switched while playing.
I didn't include any schematics here because there's already schematics for these boosts all over the place. If anyone is interested in doing a layout for a DIY project, then feel free to do so.
