PCB transfer scaling issues
- chicago_mike
I printed the psb to scale, but the pinout for the TL074's are too close together to safely solder in the chip or a stand-off.
is there a revised pcb layout or what do I do short of making another pcb?
Skyline FX 2013
- modman
- a d m i n
- Has thanked: 4287 times
- Been thanked: 2008 times
Don't trust Microsoft or your printer settings. Scale it yourself in you print settings - I learned from Bajaman to check with an opamp before you proceed.chicago_mike wrote:I printed the psb to scale, but the pinout for the TL074's are too close together to safely solder in the chip or a stand-off.
Could you link to the layout in question so we could have a look?
Good luck!
I've taken to printing a handful of differently sized transfers on regular paper and then going thru each one with a transistor socket and (if on the pcb) an opamp socket. I physically lay them on the paper and make notes of which sizes are the best fit. Only once I narrow it down to the best resizing do I break out the PnP. It only takes a few minutes and with practice you get a better feeling of how poorly Microsoft distorts images in various viewing modes.
-chris
-chris
"I've traveled the world and never seen a statue of a critic." -L.B.
- danielzink
- Completed builds: Too many: www.danielzink.com
- Has thanked: 8 times
- Been thanked: 27 times
I do the same thing. I'll print out my circuit on regular paper - then go to the bench and punch out the "pads" with a safety pin and start test fitting components.cpnyc23 wrote:I've taken to printing a handful of differently sized transfers on regular paper and then going thru each one with a transistor socket and (if on the pcb) an opamp socket. I physically lay them on the paper and make notes of which sizes are the best fit. Only once I narrow it down to the best resizing do I break out the PnP. It only takes a few minutes and with practice you get a better feeling of how poorly Microsoft distorts images in various viewing modes.
-chris
Dan
http://www.danielzink.com
MoonWatcher wrote: Silent ain't better. If someone cracks the shitwind, I want to know what's headed my way. Silence is for the library and the cemetery.
- chicago_mike
Its that danged neutron that I was having issues with.
Ill try the resizing thing like you guys say.
Skyline FX 2013
