PCB transfer scaling issues
Posted: 07 Aug 2008, 15:04
by chicago_mike
I printed the psb to scale, but the pinout for the TL074's are too close together to safely solder in the chip or a stand-off.
is there a revised pcb layout or what do I do short of making another pcb?
Posted: 07 Aug 2008, 21:46
by modman
chicago_mike wrote:I printed the psb to scale, but the pinout for the TL074's are too close together to safely solder in the chip or a stand-off.
Don't trust Microsoft or your printer settings. Scale it yourself in you print settings - I learned from Bajaman to check with an opamp before you proceed.
Could you link to the layout in question so we could have a look?
Good luck!
Re: PCB transfer scaling issues
Posted: 10 Aug 2008, 15:12
by cpnyc23
I've taken to printing a handful of differently sized transfers on regular paper and then going thru each one with a transistor socket and (if on the pcb) an opamp socket. I physically lay them on the paper and make notes of which sizes are the best fit. Only once I narrow it down to the best resizing do I break out the PnP. It only takes a few minutes and with practice you get a better feeling of how poorly Microsoft distorts images in various viewing modes.
-chris
Posted: 14 Aug 2008, 00:53
by danielzink
cpnyc23 wrote:I've taken to printing a handful of differently sized transfers on regular paper and then going thru each one with a transistor socket and (if on the pcb) an opamp socket. I physically lay them on the paper and make notes of which sizes are the best fit. Only once I narrow it down to the best resizing do I break out the PnP. It only takes a few minutes and with practice you get a better feeling of how poorly Microsoft distorts images in various viewing modes.
-chris
I do the same thing. I'll print out my circuit on regular paper - then go to the bench and punch out the "pads" with a safety pin and start test fitting components.
Dan
Posted: 23 Aug 2008, 21:24
by chicago_mike
Its that danged neutron that I was having issues with. :lol:
Ill try the resizing thing like you guys say.
