De Profundis delay
- snk
Hello,
I am interested into the Grind Customs "De Profundis" delay, as it is supposed to be a DIY project, featuring a hi-pass tone trimmer (which i am interested into studying).
Unfortunately, the website seems gone for a while, andthe layout from doesn't feature the aforementionned tone trimmer.
Could anyone help about telling me where this trimmer is supposeed to be, and/or where to find teh schematic as well as a veroboard layout, please ?
Thank you in advance,
- marshmellow
It's also marked as offboard wiring in all the layouts.There is also a tone control trimmer to adjust the high pass cutoff frequency on the repeats.
- snk
Offboard wiring ? So you mean it's the tone knob ?
I thought the tone knob was the usual lowpass, to filter out the high frequencies (like every other PT2399 delays), not a hipass getting rid of muddy bass...
Would you have a link to any other layout than the TagBoardFX one ?all the layouts.
- snk
Thank you so much, Karul !
So the 10K (trimmer on the build doc / pcb, and knob on the veroboard layout) is actually an hipass filter ? This is rather unusual, and interesting...
This may mean that the De Profundis is natively low-pass filtered (and that you can not adjust that, unlike many other delays) ?
- snk
Little bump : I'm looking to build a PT2399 delay which is not too dark, and i am hesitating between building either theDe Profundis Delay or the Wampler Faux Echo...
It seems that both are rather similar, but the De Profundis layout is quite smaller, with less traces and cut, so the lazyness in me tells me that if both should sound near identical, there is no reason to go for the Wampler (also a smaller veroboard might be easier to tweak)....
However, maybe that the Wampler is better, so if it is true, there is no reason not to buy it
Does anyone have an opinion about one vs the other ?
- jeepe
- Completed builds: I might be at level 2, so to speak..
not totally green, but that's all :)
my "level" is about building a big muff... medium complexity :)
I'll never build a DS-2, for example :)
even though I'm a layman to electronics
I'll never build anything without seeing the actual schematics too...
my all time favorite: Fuzz FAce
it is an always ongoing project..
I want to end up strumming some strings at the end of the day, whatever the sound
I'm so sad that this beautiful culture (and freedom movement) is totally ephemeral - Location: Budaspest, Europe
- Has thanked: 568 times
- Been thanked: 21 times
It seems clear that breadboarding such a big circuit doesn't make sense...
but it would have been nice to know what the result of your project turned out to be in the end...
pedal building, tracing and sharing is such a beautiful freedom movement... If only it could be viewed as a future heritage, but it really is ephemeral, as it seems
