Is there any way to test 3207 and 3102 BBD chips?
Rambozo96
Completed builds: Superfuzz’s, Mosrite Fuzzrite, various Tonebenders, some oddball Russian stuff, MXR Distortion II, modded various DOD pedals to true bypass, opamp Big Muff.
Has thanked: 10 times
Been thanked: 40 times
Post by Rambozo96 »
I recently got a newer Arion Stereo Chorus that only outputs a clean sound when engaged and I don’t want to just shotgun parts into it hoping it works. I would guess maybe the first culprit would be one of the BBD chips but I’d like to know if there was a way to test them to make sure.
deltafred
Has thanked: 808 times
Been thanked: 299 times
Post by deltafred »
I recently had 2 (identical) choruses in to repair (Identical schematic to the Behringer UC100), one had bad noise on the chorus signal, the other only had clean output.
I downloaded the datasheet for the 3207 and 3102 and found that on the second one there was no output from the 3102 (pins 7 & 8) so I robbed the chip out of the noisy one and got one working.
The first one was noisy even without the 3102. I tacked this down to a surface mount transistor, it was either a bad joint or a noisy transistor. I swapped it and that cleared the noise. I then ordered a 3207 and 3102 pair from China (dirt cheap), replacing the 3102 restored the chorus signal.
Total cost 0.99 GBP and one transistor pulled from a random scrap board.
deltafred
Post by deltafred »
deltafred wrote:(pins 7 & 8)
That should read pins 7 & 8. 8 followed by a closing round bracket must be the code for a smilie!
Has thanked: 218 times
Been thanked: 857 times
deltafred wrote:I. I then ordered a 3207 and 3102 pair from China (dirt cheap),
So did I years ago! They looked fine I thought.... but got very hot once powered. I learned a lot about Chinese fakes since that time. And, over the years I more and more get amazed that the attitude of absolutely not caring about selling fake stuff, reworked stuff and all other forms of fraud is so common in China.
deltafred
Post by deltafred »
Dirk_Hendrik wrote:So did I years ago! They looked fine I thought.... but got very hot once powered. I learned a lot about Chinese fakes since that time. And, over the years I more and more get amazed that the attitude of absolutely not caring about selling fake stuff, reworked stuff and all other forms of fraud is so common in China.
I got mine in August 2018, I only used the 3102 and it worked fine so guess I was lucky.
I did think at the time that I might be wasting 0.99GBP but figured it was worth the risk! :lol:
