Yack - YF-2 Fuzz Box
- george giblet
Old and Rare.
Some parts are not known but I have worked out good estimates.
The filters (C6 and C8) were matched by using the sound samples.
Yack YF-2 Fuzz
Japan
1967 to 1969
http://www.effectsdatabase.com/model/yack/yf2
good pics:
http://electricpartslibrary.hatenadiary ... 0160803/p1
Sound sample from electricpartslibrary page: (if this link doesn't work go via previous page)
https://ec-media.sndcdn.com/ouZUywJZSjZ ... 4592d02735
v good pics:
https://reverb.com/item/3944443-yack-yf ... anese-fuzz
Comments, additions, fixes welcomed.
Yack YF-2 Fuzz
Japan
1967 to 1969
good pics:
v good pics:
- george giblet
- modman
- a d m i n
- Has thanked: 4287 times
- Been thanked: 2008 times
- pn66c8soljv8koih39ys-2.jpg (43.63 KiB) Viewed 3642 times
- fxgomu1r7svcpgtaodp1.jpg (66.68 KiB) Viewed 3642 times
- h4l9ggdkgaefpxybnb3h.jpg (65.71 KiB) Viewed 3642 times
- m9jx9emevn6gvlcplrqk.jpg (67.68 KiB) Viewed 3642 times
- nuikwehbigzxbuzbwhla.jpg (48.54 KiB) Viewed 3642 times
- pn66c8soljv8koih39ys-3.jpg (43.63 KiB) Viewed 3642 times
- Dirk_Hendrik
- george giblet
It's a valid question. I did put some thought into it even though it may be wrong.What is the 1967-1969 reference based upon?
The 1967 was based on the electrolytic caps (early 1967). The range was something I found on the internet so it's an unofficial range.
There is another Yack product, the DA-1 Fuzz Box, which is very similar but not a 100% copy of the Ace Tone FM-1; the PCB looks identical but different parts are loaded. The FM-1 dates 1966/1967 through to 1968/1969; again unofficial figures.
So putting that loose info together I thought the 1967 to 1969 range from the internet was believable.
Given the rareness of the Yack pedals it's going to be had to get enough samples to improve the answer.
- toneman
- my favorite amplifier: anything that works
- Completed builds: meatolation, wobolation, ringolation clones, PAiA synths/modulars, dipthonizer clone, MOTM modules, pedal mods and repairs
- Has thanked: 178 times
- Been thanked: 45 times
the yf-2 box looks "flatter"(wider) and has a switch. the da-1 does not. Extra filter caps(?)
I luv old fuzzes..
not much info at
http://www.effectsdatabase.com/model/yack/da1#pictures
I luv old fuzzes..
not much info at
Tone-to-the-Bone
- george giblet
From the outside that's it. They follow the wedge style enclosure from that era. Inside they are quite different.the yf-2 box looks "flatter"(wider) and has a switch. the da-1 does not. Extra filter caps(?)
The Tack YF-2 is unique, other than the similarities to the Fuzz-Face type ckt.
The Yack DA-1 is very similar to the Ace-Tone FM-1 but it's not a direct copy even though the PCB looks identical.
The DA-1 and FM-1 both use a similar ckt to the Maestro FZ-1. This group are all 3V units.
Analog guru did a partial schematic in 2007 for the Ace-Tone FM-1. The schematic has a few bugs, not because of tracing issues but because he had limited pics to work from - that's life tracing from pics. I've been able to gather a little more info but still not enough to create a complete schematic. I'll put up what I have when I have more time.
Yes, until the internet I didn't realize there we so many from the 60's. Sometimes I don't like the sound 'out of the box' but they can be tweaked. LucifersTrip has done quite a bit of tweaking.I luv old fuzzes.
For some units there very little info.not much info at
I like the idea of documenting what these things actually were. It takes actually takes quite a bit of work. Without all the people on internet pitching in with snippets of info it would be an impossible task.
- george giblet
Very interesting, there's also a YF-1. It doesn't have a switch.
http://www.effectsdatabase.com/model/yack/yf1
It uses the YF-2 PCB. Clearly some parts for the switch are not loaded on the YF-1.
Another one!
Another one!
- toneman
so......
maybe........
there's a da-2
the one with a switch
yeh, the interweb allows folks from around the world to come together for a chance of fuzz
maybe........
there's a da-2
Tone-to-the-Bone
- george giblet
You never know! We know what to look for now.there's a da-2
There's no way I would have recognized the YF-1 without having looked at the YF-2.
- jeepe
- Completed builds: I might be at level 2, so to speak..
not totally green, but that's all :)
my "level" is about building a big muff... medium complexity :)
I'll never build a DS-2, for example :)
even though I'm a layman to electronics
I'll never build anything without seeing the actual schematics too...
my all time favorite: Fuzz FAce
it is an always ongoing project..
I want to end up strumming some strings at the end of the day, whatever the sound
I'm so sad that this beautiful culture (and freedom movement) is totally ephemeral - Location: Budaspest, Europe
- Has thanked: 568 times
- Been thanked: 21 times
hi,
this is a very good sound sample, from 2017 at soundcloud.com
notice that it features the pic that modman posted
pedal building, tracing and sharing is such a beautiful freedom movement... If only it could be viewed as a future heritage, but it really is ephemeral, as it seems
