Almost all the part values and connections are good to see, so one should be able to do pretty good trace of this.
The only tricky part is that there are smd parts on both sides of the pcb
Why shouldn't be post it?? It's not an open invitation for people to copy his stuff.Seiche wrote:This is openly accessible on your instagram, why would you even post it?
I can only guess what you are referring to, but I assume it's about the lm/ne555. R.G. himself posted the following advice here, maybe it helps:trampled_empire wrote:Let me know if you figure out how to overcome the issues inherent in the one design here. I ended up switching out a good chunk of it for something else.
R.G. wrote:There is a useful rule in designing effects - don't use the NE555. The NE555 has huge current spikes in its power and ground supplies right at the places where its output switches. Instead, use the LMC555 or one of the other CMOS versions that do not have the big current spikes.
I posted this photo. You commented "I'm gonna trace this".Seiche wrote:This is openly accessible on your instagram, why would you even post it?
Nope. Again, just because the footprint just says 555, that doesn't mean that's the exact part I'm using. The CMOS thing is fairly well-known.Seiche wrote:I can only guess what you are referring to, but I assume it's about the lm/ne555. R.G. himself posted the following advice here, maybe it helps:R.G. wrote:There is a useful rule in designing effects - don't use the NE555. The NE555 has huge current spikes in its power and ground supplies right at the places where its output switches. Instead, use the LMC555 or one of the other CMOS versions that do not have the big current spikes.
So it has come to my attention that it is not a 'unique' design, but may be based on the Keeley Magnetic Echo with a tone control and maybe some extra modulation. ILF talked about this matter-of-factly in february, and the early versions even used a PedalPCB Magnetron pcb. One can clearly see the PedalPCB logo in the gutshot. So I don't get the outrage about 'tracing and stealing designs' etc.bmxguitarsbmx wrote:If it is a unique design, I prefer we leave it slightly protected. If it's not, I prefer it be exposed.
Burned...Seiche wrote: So it has come to my attention that it is not a 'unique' design, but may be based on the Keeley Magnetic Echo with a tone control and maybe some extra modulation. ILF talked about this matter-of-factly in february, and the early versions even used a PedalPCB Magnetron pcb. One can clearly see the PedalPCB logo in the gutshot. So I don't get the outrage about 'tracing and stealing designs' etc.
together with this related statement on reddit by trampled_empire this makes me think this is some kind of bandpass: "The ability to use the 'tape quality' knob to mix the lower mids out of the wet signal makes it possible to have the repeats turned up and busy without muddying up the dry signal."Seiche wrote:maybe that pot varies R12 and R13 simultaneously to make the tone control with the wiper going to pin 14 of the pt2399
While I have not frequented or contributed to this site in the past and really have no grace to fall from, I do my best to take the time to answer any questions anyone has about circuitry and share cool circuits that I think others might find useful elsewhere. I'm not going to stop doing that, but this experience has simply taught me to be more careful about what I share publicly.captain_tango wrote:It's always sad seeing when someone falls from grace within the strict open sourcedness of this forum, especially when they've been pretty helpful elsewhere. Steve seems like a good guy, but I wish he realised that trying to hide a circuit is only going to make people here try even harder at finding out what's under the hood.
More people, especially people trying their luck in the game of selling pedals, should take note of this.
Transparency does in fact not really kill your sales, quite the contrary. Sharing is caring and those who want to build your stuff, will find a way no matter what you do to avoid it. Best case scenario is you share something with such an inherent kindness and respect for the flow of future development of the guitar pedal universe that even some of these modders and tweakers who never buy anything may at the very least recommend your stuff to those who do!
That's just me, and I have to live with me.
