Haz Labs - NYC - Mutron III +
chicago_mike
Has thanked: 22 times
Been thanked: 316 times
Post by chicago_mike »
The Mutron III ( re-issue ) that's been around for a while. Not really a re-issue unless you count mainly just the case.
Cosmetically the case looks to be the same manufacture, the paint scheme is also similar to units with the power switch. Theres an added notch filter in the mode section and instead of a gain control, its been changed to a depth control. Powered by 2 x 9volts or a 24 volt adapter.
The guts are all smd which is not bad. But I don't see any ldr setup insight.
The sound? Meh. It's okay. Not as unpredictable as an original mutron.
So I'll be gutting these and putting in an original based circuit. I don't mind the work.
Piccies as below.
Skyline FX 2013
chicago_mike
I have to crop my images!! OOPS!
Skyline FX 2013
chicago_mike
http://michaelstram.com/mutron/ : Link to the pictures directly
Skyline FX 2013
