Baja Trembulator schematic, board layout and circuit board [documentation]
- DimebuGG
Hi Bajaman,
Any thoughts using a quad opamp on this?..Actually, I've design a layout using a quad opamp.
I have a bit of a weird problem, I built this pedal using a perfboard layout I did myself, so I probably messed up somewhere I'm just having a hard time locating the exact problem. Here's what happens, when I first power up the pedal everything works but only for 2-3 seconds, the light is flashing and it tremolo's fine, but over those first few seconds the led flashes less and less until it is just constantly lit up, at this point the tremolo stops. I'm assuming that the led in the LDR is doing the exact same thing, which would explain why it isn't working properly. Somewhere on the board power is building up and not draining properly. I made the board in two pieces because I combined it with a zvex style sequencer, so I can switch between normal tremolo controls and the sequencer. here's an image of the layout of just the two boards pertaining to this pedal. The board on the left is the schematic from the input up to the LDR, the board on the right is all the controls and that is where the problem is because the pedal works just fine with the sequencer controls (not shown)
- jrc4558
I have finally got to testing m own layot for this smooth sounding tremolo. It worked, minus one minor error (Ratepotentiometer was connecting to the ground instead of Vref). Now I have a couple of questions about this effect.
While I love the shape of the LFO, I can't help but to want more depth and higher speeds. I think reducing the 10k that connects to the 50k Rate potentiometer should do the trick. The depth issue, however, seems to be entirely dependent of the LDR, as there is no resistor before it to alter the value of the voltage divider and such. What I really am looking for is the speed and depth of Pink Floyd's Money, which I do get with EA Tremolo. now, I've always wanted a tremolo with no volume control to it, and Trembulator seems a wonderful candidate if I could tweak it a bit. What would you recommend to increase the depth of this effect? I am thinking a j-fet with gate to where the optoisolator's LED+ side connects right now. Any other suggestions?
Thank you Baja for the wonderful project!
- jrc4558
I think I should refine what I mean by Depth here. I don't mean the about of LFO signal modulating the resistance of the LDR. I mean a greater amplitude, or swing in maximum and minimum volume when the Depth is at maximum.
- bajaman
- Has thanked: 566 times
- Been thanked: 2014 times
For a greater depth try reducing the 50k depth control to 10k and increase the output coupling capacitor from 1uf to 4.7uf.
That should do the trick.
Louishr wrote:I have a bit of a weird problem, I built this pedal using a perfboard layout I did myself, so I probably messed up somewhere I'm just having a hard time locating the exact problem. Here's what happens, when I first power up the pedal everything works but only for 2-3 seconds, the light is flashing and it tremolo's fine, but over those first few seconds the led flashes less and less until it is just constantly lit up, at this point the tremolo stops. I'm assuming that the led in the LDR is doing the exact same thing, which would explain why it isn't working properly. Somewhere on the board power is building up and not draining properly. I made the board in two pieces because I combined it with a zvex style sequencer, so I can switch between normal tremolo controls and the sequencer. here's an image of the layout of just the two boards pertaining to this pedal. The board on the left is the schematic from the input up to the LDR, the board on the right is all the controls and that is where the problem is because the pedal works just fine with the sequencer controls (not shown)
did you ever figure this ot mines doing the same
Hi.ron123 wrote:Louishr wrote:I have a bit of a weird problem, I built this pedal using a perfboard layout I did myself, so I probably messed up somewhere I'm just having a hard time locating the exact problem. Here's what happens, when I first power up the pedal everything works but only for 2-3 seconds, the light is flashing and it tremolo's fine, but over those first few seconds the led flashes less and less until it is just constantly lit up, at this point the tremolo stops. I'm assuming that the led in the LDR is doing the exact same thing, which would explain why it isn't working properly. Somewhere on the board power is building up and not draining properly. I made the board in two pieces because I combined it with a zvex style sequencer, so I can switch between normal tremolo controls and the sequencer. here's an image of the layout of just the two boards pertaining to this pedal. The board on the left is the schematic from the input up to the LDR, the board on the right is all the controls and that is where the problem is because the pedal works just fine with the sequencer controls (not shown)
Try to break the track that goes straight down from the left side of R9 on the layout.
I build the circuit today using the scematic and Louishr's layout (on one board though) and after a couple of rookie mistakes I've got it right. Sounds great all though my Depth knob isn't working proberly. When I turn it clockwise the signal is boosted a bit and the tremolo effect is less audible. I've also reversed the Rate knob somehow as the speed decreases when turned cv.
Aside from my mess ups it's a great build. I use it for bass and it's really smooth.
Martin
- Completed builds: Mini Booster, EA Tremolo, Timmy, Sagitarian Charger, Trembulator, 60's Fuzz, Dig Dug, Great Cheddar, BD2, Neovibe, Vibratone, Rangemaster, Warm Pie, Komprossor, Vox Repeat Percussion, CE 2, Tychobrae Octavia, Rangemaster, Burns Buzzaround, Green Fuzz,
kia ora baja
just building this up now, can i use an LM358 in place of the LF442?
- bajaman
I suppose you could use the LM358, although I have not tried it.
- devastator
i think I'm gonna make that tremolo pedal, but just one question, I can have a chopped sound with it ? an extrem tremolo ? or that stay soft even with the speed at max ?
thanks for that bajaman, fnished it today with LM358 and homebuilt vactrol with red LED, garden pipe and LDR, sounds fantastic!!! thanks for the build notes...replaced 10k with 4k7 for faster rate speed...very happy with this, highly recommended...has more depth than the EA in my opinion...thanks once againbajaman wrote:I suppose you could use the LM358, although I have not tried it.
BAJAMAN HELP!! I've built the Trembulator but cannot seem to get it to work properly. All the parts are correct, even shelled out the cash for the VTL5C1 but when i first plugged it in the LED came on but was solid and not pulsating... when i picked up the board it suddenly began to trem, i realized i had my fingers in specific spots on the board (ground and speed pot solder points) and when i attached a wire to jump from those two points it began to work... BUT it only pulses at about half the rate... here's where it gets weird (and possibly not for you but for me because i'm still new to the game) when i place my finger on a specific spot on the solder side of the board (again, totally by accident i discovered this) it pulses like crazy at the speed i'd ultimately want.... the spot seems to be around the 4k7, 18k, 220n, and 2m2 just below the LF351 chip.... i have no idea what i may have done wrong here, but do you have a clue....?
by the way, this is the third Baja build i am doing, the first to not work right away, as silly as this is consider yourself admired, all my baja builds are my favorite pedals by far (and i have some pretty $$$ boutique stuff as well)....
is it wrong that i imagine Bajaman on a cliff with a cape and soldering iron ready to combat evil and newbie dork mistakes.....?
Hi Sonicv, i like this idea and have recently built up a board of the Vibratone plus one for the Trembulator, can you describe how you the rotary switch works and how you have it wired? Cheers Andrewsonicvi wrote:Here's a clip. I put the Trembulator and RG Keen's Vibratone brownface vibrato in one box with a three way rotary switch (trem/vib/vib into trem). This clip has all three, but the Trebulator starts at about 1:45. One resistor controls the maximum speed, so you can set it to whatever you want really. I don't think this clip has the fastest or slowest that my build is capable of. Its a fantastic tremolo. If you want the Blackface tremolo sound you won't be disappointed. Kudos to Bajaman.![]()
http://homepage.mac.com/sonicvi/bandt.mp3
- devastator
it's possible to add a third control into the circuit (for the shape maybe) ? Otherwise I'll add a volume stage at the end (like the tremulus lune)
I'm gonna order the PCB to make that tremolo pedal which seems to sound really cool.
- mictester
Hibajaman wrote:Hi
Baja Trembulator pcb tracks
Baja Trembulator board layout
I found that your tremolo is fabulous - thanks for contributing it. However, I found that it could be affected by the input impedance of the following device (whether another stompbox or an amplifier), so I added another op-amp with unity gain just to give a low impedance output. You could use an additional IC or make the first stage a dual (TL 062). A suggested schematic is attached:
You'll find that this makes the device more useable at little extra cost. I'll forward my modified PCB design if anyone wants it.
- sinner
- Has thanked: 1031 times
- Been thanked: 907 times
mictester wrote:I'll forward my modified PCB design if anyone wants it.
- devastator
the PCB in frst post is correct ? I'll make an order to build that tremolo.
- mictester
Certainly will. It's on another machine, and I'm enjoying the cricket this afternoon. I'll post either later today or tomorrow.sinner wrote:mictester wrote:I'll forward my modified PCB design if anyone wants it.Would you like to post it here?
- sinner
Lovely, good luck then and thank youmictester wrote:Certainly will. It's on another machine, and I'm enjoying the cricket this afternoon. I'll post either later today or tomorrow.sinner wrote:mictester wrote:I'll forward my modified PCB design if anyone wants it.Would you like to post it here?
