Do you really need to Match SMD JFETs?
Jcknowles89
Post by Jcknowles89 »
Hey all,
about to start building a Phase 90. Was doing some research and from what I saw the type of JFET used to Bias the Op amp phase shifters doesn't matter as long as they're matched (correct me if I am wrong on this). I normally try to use SMD JFETs in most of my builds (MMBFJ201 or MMBF5457) just because they are easier to get a hold of. I have also heard that SMD JFETS have significantly better Tolerances and don't necessarily need to be Matched? Anyone confirm this?
Thanks,
Has thanked: 218 times
Been thanked: 857 times
I would not dare to blatantly confirm. But my own experience is that when I use JFEt's that come from the same reel there's very little difference. First, and only, time I did JFET matching I got such identical results I started to doubt my setup.
julessouren
Been thanked: 9 times
Post by julessouren »
Just my 2 inexperienced cents, but I believe the actual wafer production quality is independent of the device packaging.
So, you might have a big wafer of transistors, being cut up into individual dies. Depending on performance or spec, they might bin or name the parts differently, but nothing has changed in the wafer production process when going from rather obsolete THT TO-92 packaging to modern SMD SOT-23 packages.
In other words, the individual fets on the wafer still have a (too) wide parameter spread, just as much with SMD devices as with THT devices.
