Baja Active EMG Schematic [schematic]
- copachino
does anybody have the baja schematic for active pickups??, id would like to try it but i have seen many different sch everywhere, so im looking for it in here, if BAJA can tell me will be amazing, looking for the EMG81, also if anybody have the LM4250 on smd eagle library its welcome too
- bajaman
- Has thanked: 566 times
- Been thanked: 2014 times
google is your friend
https://www.electrosmash.com/emg81#link5
scroll down
Moderator: modified the link to go directly to the Bajaman's schematic and added the schematic to this post. Make sure you check the article, though, it's a treasure trove of information regarding both Bajaman's schematic and active pickups.
scroll down
I know the site but cant see schematic before my bad sorry I cant find the MMDB701 Diode. Have any replace for it
- EddieTavares
Rauch
This diode does nothing to the signal, it is only reverse power flow protection so you can use anyone.
- EddieTavares
Yes, it'll work perfectly!
An option something better is to use an schottky diode, anyone. There is a little voltage drop (aprox. 0,6v) when 1N4148 is used in this way, it does not affect your tone when the battery is fully charged.
Another good Idea is to use it in parallel as it is used in pedals.
I found mmbd diode footprint and add it bit I cant understand one thing 4205 pin 4 ground and pin 7 to 9v+ is it ? Or something else ?EddieTavares wrote:Yes, it'll work perfectly!
