I wanted to put it into the same box footswitchable with a silicon fuzz face, I didn't need the octave knob so I stream lined it:
also added resistors before and after to adjust the volumes...
this all sounded perfect on breadboard, however when I finally boxed it up , all three resistors, 50R, 1M & 100k resistors, get VERY hot, like cooking, almost too hot to touch, I think it was starting to smell too, no good. Caps and 2n7000 actually seemed fine but warmed from the resistors. The fuzz face side of the circuit is completely fine not heated.
Do you see anything wrong with this? I can post the entire schematic if that helps.
Thanks for any help!
