Works fine when the effect is engaged (sounds great) but when bypassed there's hardly any signal passing through.
Opened it up to check the footswitch connections and found a small multiplug that's not attached to anything - two red wires with yellow stripes and a green ground wire.
Can't see any terminals it might be meant to plug onto, and am wondering whether it came loose in shipping or if perhaps it's unneeded after the mod and was just left hanging.
AFAIK this model is essentially the same circuit as the Chicken Salad vibe, though it has an Intensity knob while the CS doesn't.
Not too knowledgeable about electronics (though I can operate a soldering iron) and would rather not take the whole pedal apart unless absolutely necessary.
I think moving the pot is not uncommon and it's a simple a mechanical mod, not electronic. So I'm hoping the problem is just a connection somewhere. Probably the little plug?
Anybody familiar enough with these to clue me in?
Here's the new knob location on top rather than on the side
and here's the little three-conductor plug; I gently pulled it off to one side for easier visibility in a crummy cellphone pic
PS: Footswitch connections are covered by black tape in the pic but they look to be fine.
