Fulltone - 69
- Contact:
- Alex Frias
Or...
Q1 hfe ~ 88, Q2 hfe ~ 123, C2 22uF!
Don't forget to adjust the trimpot for more-than-excellent sound!
- alteredsounds
Maybe you could buy one, reverse it and share on here if you want a 100% accurate copy, also maybe a bit more gratitude to those who've already tried to help might be good and help your causeoneleg wrote:HELP!!!!!I WANT!!!!!!
Torchy
oneleg wrote:I WANT THE REALFulltone 69 Schematic.thanks all the time
FFS grow up. If you want it that bad do some bloody work yourself. Here's a head start. Get tracing.oneleg wrote:HELP!!!!!I WANT!!!!!!
Now compare it with the deatails on this website
http://hardbop.blog6.fc2.com/blog-entry-175.html
BTW, that took all of 10 minutes searching.
- earthtonesaudio
By the way, the LED in the GGG schem is backwards.
- Bernardduur
The 18k resistor in the Fulltone is for the LED.
- analogguru
.... and the output coupling cap is only 10n (instead of the 100n shown in the schematic). The rest is like in the four units I had for tracing.
BTW, the ß of the first transistor varies between 84 and 96 and the second between 105 and 128.
- paperhouse
I built this a while ago, sounds great. I don't remember where it came from.
- PurplePeopleEater
paperhouse wrote:I built this a while ago, sounds great. I don't remember where it came from.
Note that the transistors need to be flipped 180 degrees from how they are shown on the layout.
- paperhouse
really?PurplePeopleEater wrote:paperhouse wrote:I built this a while ago, sounds great. I don't remember where it came from.
i built that one as the layout suggests and it works fine. i guess i'll try flipping them
- PurplePeopleEater
The emitters should be toward the bottom of the board, away from -9V. The way it's drawn shows them to be pointing toward -9v. Check any FF schematic to compare.paperhouse wrote:really?PurplePeopleEater wrote:paperhouse wrote:I built this a while ago, sounds great. I don't remember where it came from.
Note that the transistors need to be flipped 180 degrees from how they are shown on the layout.![]()
- devastator
- IvIark
Input goes to bias pot, output is from volume pot, take the positive ground to somewhere on the bottom strip.
