Pédale de Vibrato et de Super-Aigues, Haut-Parleur 1967, 🇫🇷
Free online ressources on guitars, amps, effects, guitar technique and more. Dedicated to the fond memory of its founder SPeter Davidoff.
Rambozo96
Completed builds: Superfuzz’s, Mosrite Fuzzrite, various Tonebenders, some oddball Russian stuff, MXR Distortion II, modded various DOD pedals to true bypass, opamp Big Muff.
Has thanked: 10 times
Been thanked: 40 times
Post by Rambozo96 »
Hello all I have stumbled upon a schematic with a treble booster and a tremolo effect from a French DIY magazine. What strikes me as very odd is how the aforementioned treble booster uses 2 transistors. They kinda look like 2 identical gain stages running in series. I got the circuit built on PCB and ready for final assembly since curiosity got the better of me. A schematic is provided for those also curious about this or anyone that can shed light on how this circuit works as a treble booster.
Schematic
Schematic
idy
Completed builds: FFs, Octavias, TBMKIIIs, Buzzarounds/alikes, Axis Fuzz', CS Overdriver, BMPs, Black '65s, MOSFETODs, WiiO, RAH, Klons, AC30, DLS, TSs and many variants, Small Clones, UniVibes, E. Mistress, Mutron Env Filter, Ross/Dynacomps,, EA Trems, TremLunes, Katana Boosters, BYOC Tri Boosters, other boosters and buffers, PT2399 delays, SKRM based delays, Belton Brick Reverbs, 3band parametric EQ,
Has thanked: 27 times
Been thanked: 31 times
Post by idy »
The first transistor is a booster. Then there is a "T" filter that cuts bass. The second transistor is a gain recovery stage. So your signal is super hot and super aigue.
Posting this partial page from the French electronics magazine Le Haut-Parleur on Facebook turned up the missing page.
Rambozo96
Post by Rambozo96 »
I finally got around to building this, used MP11A NPN Russian germanium so I don’t need a charge pump for the circuit. It’s very thin sounding and almost unusable with how much high end it pumps out. Maybe the T filter can be tweaked to tame the ice pick highs? Probably doesn’t help that I used a Danelectro in the demo.
Thanks for that clip - I don't think anybody has an excuse for demo clips anymore :D
Did you build this part of the circuit or the whole thing?
It may be the transistors, if not start jumpering the filtering between the two transistors. Dropping first 1n5 and the 10k resistor...
Rambozo96
Post by Rambozo96 »
Just the treble booster side. I attempted the whole thing last year and couldn’t get either to work BUT my laying out schematics to PCB skilled were fairly weak then. I guess I’ll try different transistors first and see what happens from there.
mictester
Has thanked: 32 times
Been thanked: 825 times
Post by mictester »
It's NOT a vibrato - it's a badly designed germanium TREMOLO. It might (sort of) work, but there are LOTS of better circuits around to do this. The treble booster is also poorly designed and will have more hiss than signal!
BMS1971
Has thanked: 42 times
Post by BMS1971 »
modman wrote: 20 Dec 2019, 12:25 Thanks for that clip - I don't think anybody has an excuse for demo clips anymore :D
I made it, sound week, BUt with a little change it's a great overdrive ;-)
Benoit
Rambozo96
Post by Rambozo96 »
BMS1971 wrote: 19 Sep 2022, 19:50
Benoit
What changes did you make? I thought about revisiting this on a breadboard and messing with the filter section
BMS1971
Post by BMS1971 »
Rambozo96 wrote: 03 May 2023, 05:57
remove T filter in between and put put a 100NF in replacement
