What is this R doing at the fb loop?
Enrulado
Post by Enrulado »
I know it may be fairly simple, but i'm having some trouble figuring it out ... why is R23 there?
I guess it's a compression thing, but not for sure.
It's the schematic of a SS Fender Amp ... nice cleans but awful (really, disgusting) distortion channel.
Thanks!!!
https://www.dropbox.com/s/s5xzfbsclir1p ... r.jpg?dl=0
heaterman
Been thanked: 18 times
Post by heaterman »
hey!
Not shure, but i guess R23 is bypassing some signal around D3 and D4, so not all of the signal is going through D3 and D4, which means that they clip less.
Manfred
Has thanked: 1597 times
Been thanked: 1300 times
Post by Manfred »
Compared to a common diode, an LED has a significantly higher junction capacitance.
So my guess is that this junction capacitance in series with the 220k resistor will reduce the gain at higher frequencies as long as the LED and diode voltages remain below their threshold voltage.
If I am right, this would be a very tricky circuit design.
Manfred
Post by Manfred »
In this essay a diagram is shown with the curve of the capacity as a function of the voltage across the LED:
https://www.edn.com/an-leds-intrinsic-c ... c-circuit/
