turbofeedus wrote: ↑10 Feb 2020, 00:37
I started to trace and to be honest with y'all, I got bored. I did find a few discrepancies with the RC booster schematic floating around though (this is V2 version).
Hopefully someone with more motivation and less depression will pick up the torch.
I've try to trace it, something is visible, something can be guessed. It seems that the schematic is the same as the one for the V1.
Some notes:
Q1, Q2 - BC849 (2CW smd)
Metal film resistors were used only for power supply bias network.
1u, 10u Nichicon MUSE ES series bipolar caps, and one 100n WIMA in audio path.
Cant confirm the values for the ceramic capacitors, I guess they are the same.
Gain 2 pot is wired in series with the gain 1 pot with switch in parallel, that turns it on/off.
12V zener back to back protection at the input and output of the pedal. There are two more transistors on the small board with the switches. I'm not sure about the markings (one is 6Y?) , I'm almost positive that they are some fets, part of the switching circuit.
Also there are two diodes for polarity protection, one in series (schottky 1N5817), one in parallel.
What is missing on the photos is the value for the gain 2 pot. Gain 1 is clearly visible and it's B250k. I guess there's no reason the bass and volume pots values to be changed, and they are still the same, B50k and B100k. Tone pot value is visible, B50k.
turbofeedus thanks for the photos. Can you tell what was the value for the second gain pot, the one with the transparent shaft?
Schematic is already drawn I'm only missing the gain pot value.
