Reagun - Overdrive [schematic]
- Manfred
- Has thanked: 1597 times
- Been thanked: 1300 times
It is a good sounding mild overdrive to push a tube amp.
there are unknown small red diodes in the opamp negative feedback.
Here the PN-junktion curve trace of these diodes:
Here the PN-junktion curve trace of the 1S1588 diodes:
PCB-Layout Ready to print PDF-files:
SprintLayout-6.0 file:
- Dirk_Hendrik
Thanks Manfred.
No smoothing cap between th3 1Meg resistor and the diode going to the switching FET's?
- Manfred
Thanks Dirk for the closer look at the schematic, you are right there is a 47n smoothing cap, it appears in the layout but not in the schematic.Dirk_Hendrik wrote:Thanks Manfred.
Here the corrected schematic:
- Manfred
George Giblet found a bug in the Reagun Distortion schematic that has the same switching circuit as the Overdrive.
It is also the same error in the schematic.
Thanks again George.
Here is the corrected circuit:
- mirosol
...aaand a stripboard layout.
+m
+m
http://tagboardeffects.blogspot.com/
http://mirosol.kapsi.fi/
"No such thing as innocence" -Iron Chic
- Completed builds: TS-808, SansAmp GT-2, ProCo Rat, ZW-44, Rebote Delay 2.5, Boss CE-2, ssm2166 compressor, selfmade EL84 15W tube head with Engl E530 pre, Bogner Sharp - Fender Twin tube stomp preamp. 5W Plexi style SE amp.
- Been thanked: 1 time
The magic diodes, it's probably stabistors?
