Reagun - Overdrive [schematic]
Posted: 23 Feb 2020, 00:19
by Manfred
It is a good sounding mild overdrive to push a tube amp.
there are unknown small red diodes in the opamp negative feedback.
Here the PN-junktion curve trace of these diodes:
Here the PN-junktion curve trace of the 1S1588 diodes:
PCB-Layout Ready to print PDF-files:
SprintLayout-6.0 file:
Re: REAGUN Overdrive traced
Posted: 23 Feb 2020, 08:31
by Dirk_Hendrik
Thanks Manfred.
No smoothing cap between th3 1Meg resistor and the diode going to the switching FET's?
Posted: 23 Feb 2020, 12:08
by peterc
Thanks Manfred
Posted: 24 Feb 2020, 00:54
by Manfred
Dirk_Hendrik wrote:Thanks Manfred.
Thanks Dirk for the closer look at the schematic, you are right there is a 47n smoothing cap, it appears in the layout but not in the schematic.
Here the corrected schematic:
Re: Reagun - Overdrive
Posted: 29 Aug 2020, 03:48
by Manfred
George Giblet found a bug in the Reagun Distortion schematic that has the same switching circuit as the Overdrive.
It is also the same error in the schematic.
Thanks again George.
Here is the corrected circuit:
Posted: 20 Dec 2022, 15:33
by mirosol
...aaand a stripboard layout.
+m
Posted: 21 Dec 2022, 13:50
by Bulldozerrr
The magic diodes, it's probably stabistors?
