Any good resources/books on how to design a power supply?
Rambozo96
Completed builds: Superfuzz’s, Mosrite Fuzzrite, various Tonebenders, some oddball Russian stuff, MXR Distortion II, modded various DOD pedals to true bypass, opamp Big Muff.
Has thanked: 10 times
Been thanked: 40 times
Post by Rambozo96 »
Hello all I was wondering if anyone knew of any good books on the subject of power supplies in tube amps. I been planning on building a preamp section of a Laney Supergroup LA60 which looks like it is close to a Marshall with a few value changes. I imagine there’s really no one size fits all power supply to power it all up so I imagine I’d have to read up on the subject if I wanted a power supply that wasn’t noisy and powers the whole thing efficiently. Also a question I have is on the LA60 I noticed that one of the tubes which I guess acts as a buffer/booster so the tonestack doesn’t sap up too much of the signal seems to be getting 340v. I don’t understand how this doesn’t destroy the tube as unless I’m looking at the 12ax7 spec sheet incorrectly I believe it’s max plate voltage is 300v.
Thanks in advance!
ppluis0
Has thanked: 121 times
Been thanked: 278 times
Post by ppluis0 »
Hi Rambozo,
Tale a look at this link: http://www.valvewizard.co.uk/ there are several explanations about power supplies, heater connections and many other tips about tube amps.
