Gaussmarkov Eagle and LTspice tutorials
- my favorite amplifier: Yerasov Gavrosh 10
- Completed builds: Dr. Boogie - Asphyx - Holland
Sharkfin - Papaformigas - Holland
Dr. Boogie - Soulskinner - Greece
Tim Screamer - Chaedrist - Germany
Tubescreamer - Detlef Hoeller - Germany
Tubescreamer - Richard Güth - Germany
Stereo merger - the Bruceband - the Netherlands
Passive Y-box - the Bruceband - the Netherlands
Tremolo - Location: Rees - Germany
- Has thanked: 15 times
- Been thanked: 15 times
- Contact:
Try archive.org
Probably there is a snapshot made.
it is mei sizzen net to dwaen
Johannes Harald Kingma - FWS Pedals - Germany
- alexradium
I could see some with way back machine
- modman
- a d m i n
- Has thanked: 4411 times
- Been thanked: 2139 times
http://web.archive.org/web/201701101735 ... eagle-cad/
if anybody else is interested...
- aion
Don't use the gaussmarkov Eagle libraries... they're super outdated and not very well designed by today's standards. They were a game-changer when they first came out, the first pedal-friendly set of libraries for Eagle, but they don't hold up well in 2020.
His tutorials aren't great either - for example, restringing is the absolute wrong solution to any problem.
I got started on these libraries back in the day and since that time I've updated nearly every aspect of them - pad sizes, outlines, and pin numbers (for some reason many of his transistor packages are numbered in reverse to convention and this caused me to wreck a few boards early on). And I had to intentionally forget most of what I learned in his tutorials.
if you're just getting started, I'd recommend using Madbean's libraries -
https://www.madbeanpedals.com/forum/ind ... ic=25194.0
For tutorials, there are a lot on YouTube that have been made by people in our community. Here's a good series by Effects Layouts from last month, so it's hot out of the oven -
That's going to get you a lot farther than some 15-year-old resources, as influential as they were at the time.
