Box of Metal Noise Gate to Precision Drive
Posted: 09 Mar 2020, 04:01
good day guys.
Im planning to make a Precision drive clone with built in Noise gate and I found this Zvex Box of Metal's Noise Gate and I'am planning to use this in Precision drive. my question is, if I use 18volts in the circuit, will the higher voltage affects the performance noise gate? or I should put a 9 volts zener diode as a regulator?
