I need help building a 4 button footswitch
I would like to build the footswitch shown in this schematic https://www.thetubestore.com/lib/thetub ... ematic.pdf
I don't have any experience at all with something like this and i would like some guidance please.
I presume that the unmarked diodes are 1N4448 as indicated in the text, but what voltage, current and wattage rating would they be?
Are the footswitches latching or momentary? on/off or on/on?
What voltage LEDs would I need to use and do they have to be red?
The socket symbol is unknown to me, I am confused by the arrow pointing at the socket tip, is this a TRS stereo socket? What does the arrow symbolise?
Is the socket sleeve ground?
Are there any components not pictured e.g resistors for leds?
What kind of cable would I use to connect this to my amp?
Is there anything else you think I should know?
I think this should be a relatively simple build but I am a total beginner at stuff like this so excuse my lack of knowledge. I hope I haven't overwhelmed you all with my questions!
- phatt
Likely a misprint, try 1N4148felixvaughn wrote:I would like to build the footswitch shown in this schematic https://www.thetubestore.com/lib/thetub ... ematic.pdf
I'd say they are latching, others here might know more.felixvaughn wrote: Are the footswitches latching or momentary? on/off or on/on?
felixvaughn wrote: What voltage LEDs would I need to use and do they have to be red?
I'd say standard Red Leds, don't use those high brightness leds.
Standard Tip Ring socket switch tab is shown but not used. Yes sleeve is circuit Common/Ground.felixvaughn wrote: The socket symbol is unknown to me, I am confused by the arrow pointing at the socket tip, is this a TRS stereo socket? What does the arrow symbolise?
No this is the switch the rest is done inside the amp. BTW it's likely this will only work with the amplifier shownfelixvaughn wrote: Are there any components not pictured e.g resistors for leds?
thin low voltage wire, no need for shielding, Whatever is easiest to use.felixvaughn wrote: What kind of cable would I use to connect this to my amp?
Raid some old electronics gear you maybe surprised at what you can scrounge from old E Waste.
I'm sure other here can think of things that might help.felixvaughn wrote: Is there anything else you think I should know?
Thanks[/quote]
- Manfred
- Has thanked: 1597 times
- Been thanked: 1300 times
Hi felixvaughn,
As I understand it, do you have this fender amp from the schematic and do you need the foot switch because it is missing?
Yes, I have recently bought this amp without the footswitch and the tremolo is only usable if you have it.Manfred wrote:Hi felixvaughn,
- Manfred
I suppose you want to build your own foot switch.
What do you need instructions for, a circuit board and wiring?
The components can be mounted on a vero or a terminal strip,
which one would you prefer?
Yes, diy is the way to go as these footswitches are incredibly hard to find it seems!Manfred wrote:I suppose you want to build your own foot switch.
I'm planning on using terminal strip construction.
1N4448 is the low-leakage version of the 1N4148, they're still available but I don't see a reason why 1N4148 wouldn't work if you can't source them.phatt wrote:Likely a misprint, try 1N4148felixvaughn wrote:I would like to build the footswitch shown in this schematic https://www.thetubestore.com/lib/thetub ... ematic.pdf
I just want to check if this is all correct,
Here is my layout,
The switches are labeled by their first letter.
Lug 2 on every switch is not connected to anything.
4 Red LEDs
4 SPDT Latching Footwitches
4 1N4448 Diodes
2 15223B Diodes
1 Mono 1/4" Socket
I'm going to use a 1590BB enclosure.
Connected to the amp with a standard 1/4" mono instrument cable.
Here is my layout,
4 Red LEDs
4 1N4448 Diodes
2 15223B Diodes
1 Mono 1/4" Socket
Sleeve is incorrectly labelled "ring".
