Valve Jr Upgrade.
Posted: 24 Mar 2020, 17:23
by steben
OK.
I know.
I stayed with the single ended concept.
Got me a 125ESE just in time before lockdown. Wired some mods, JJ tubes and Bam! great improvement in sound.
Schematic as-built:
Now I wonder whether a blocking resistor before V2 after the volume pot might smooth the sound even more.
Is it worth it?
Re: Valve Jr Upgrade.
Posted: 24 Mar 2020, 17:33
by plush
Is it me, or you are running you heaters little bit too hot from DC (8.3 vs 6.3)? Won't this be an issue for your tubes?
steben wrote: Now I wonder whether a blocking resistor before V2 after the volume pot might smooth the sound even more.
Is it worth it?
It depends on your smoothness criteria.
You can calculate it as lpf considering miller capacitance of your tube stage.
Posted: 25 Mar 2020, 07:49
by Ben N
plush wrote:Is it me, or you are running you heaters little bit too hot from DC (8.3 vs 6.3)? Won't this be an issue for your tubes?
Does a DC filament supply really offer a noticeable improvement over a well constructed AC supply (twisted leads, virtual center tap, DC reference)?
Posted: 25 Mar 2020, 08:53
by plush
Ben N wrote:Does a DC filament supply really offer a noticeable improvement over a well constructed AC supply (twisted leads, virtual center tap, DC reference)?
IMO it makes life way more easier (no need for hum balancing, cable-twisteroo and cathode elevation). So, for me it's an improvement.
Posted: 25 Mar 2020, 11:09
by steben
It is the standard VJr circuit as is ...
(6.3 - 0.65) * 1.41 = +/- 8 V ... Unloaded.
I get around 7.2V
On the TDPRI.com forum I'v found:
Did some playing around earlier, measuring heater voltages on the amp. Stock, they're quite high, at 7.15v DC. Here's a quick list of voltages with different sets of tubes:
6.34v with EL34 and 1x 12AX7
6.19v with EL34 and 2x 12AX7
6.92v with 6L6 and 1x 12AX7
6.70v with 6L6 and 2x 12AX7
7.35v with 6V6 and 1x 12AX7
7.08v with 6V6 and 2x 12AX7
6.92 with 6L6WGB and 1x 12AX7
6.62 with 6L6WGB and 2x 12AX7
8.11v with 1x 12AX7
9.51v no tubes installed
7.15v with original EL84 and 12AX7
So ... yes. It should be somewhat lower to extend tube life. Guitar amps are simply designed over the limits everywhere, aren't they?
Current is huge (+/- 1 Amp), so any resistor would need higher power rating than standard in an instant.
Subtracting 0.5V would need 0.5V/1A = 0.5 ohms . 0.5 V * 1 A = 0.5W
-> 1 Watt resistor.
Is adding a diode in series an option? This would need a high current rating. 1N5408 has 3A.
plush wrote: It depends on your smoothness criteria.
Most calculations of examples lead to freqs well above 10k, yet the blocking distortion might be reduced - grid stopper function.
I could just do some trial and error of course.
Posted: 25 Mar 2020, 21:44
by plush
I get around 7.2V
8.11v with 1x 12AX7
-> 1 Watt resistor.
Please ignore my brain fart, i forgot to add diode drop to my calculations. 7.2 is pretty reasonable value.
Posted: 22 Apr 2020, 19:07
by soulsonic
I have a Gibson GA-5 handwired reissue, and I found that adding more capacitance to the power supply filtering gave a noticeable decrease in overall hum. I believe I stuck a 100uF cap in parallel with the existing first filter cap.
