So what do we do? Well, we go and take the dirty channel preamp and turn it into a pedal! There are a couple of small changes to it to make it a little more convenient for a pedal build, but it works quite nicely. It does a great classic rock crunch, and I used to get into higher gain territory by putting a Guv'nor in front. I really quite like it, so I thought I would share with you fine folk!
Here is a quick little demo I made of it. I used S-Gear for the clean base and the dirt is from the circuit on the breadboard, so some noise from that, for sure.
Also, here is the schematic, broken up into the power and signal sections. I'll be working on a two layer board layout soon and will add it when completed. Let me know what you think!
